Posted September 13, 200222 yr comment_15663 Does anyone know where I can get a carpet set for a 1974 Fairlady Z coupe?T Link to comment https://www.classiczcars.com/forums/topic/3018-carpet-for-a-fairlady-z/ Share on other sites More sharing options...
December 4, 200222 yr comment_20251 Sorry this reply is so late to your post.There are several sources for the 74 Z, but since you refer to it as a Fairlady, then you may have a Japanese model and therefore, right hand drive. Motorsports, Victoria British are but two sources I can think of, but you'd have to contact them to find out if they have RHD carpeting. (The difference will be in the reinforcement for the accelerator pedal and cut-out for the throttle stop).Hope this helps. Link to comment https://www.classiczcars.com/forums/topic/3018-carpet-for-a-fairlady-z/#findComment-20251 Share on other sites More sharing options...
September 11, 200321 yr comment_49390 http://www.classicdatsun.com/They can special order RHD carpet kits for you. Link to comment https://www.classiczcars.com/forums/topic/3018-carpet-for-a-fairlady-z/#findComment-49390 Share on other sites More sharing options...
