280z4me Posted December 9, 2008 Share #1 Posted December 9, 2008 Car will turn over, run for 4-5 seconds, then shut off. I was going to get a fuel pressure guage to see if the pump is working(around 30psi I suppose???) What else can I check for if its not the fuel system? Would it be the computer? Link to comment Share on other sites More sharing options...
Zedyone_kenobi Posted December 9, 2008 Share #2 Posted December 9, 2008 Can you give us more info on what year your Z is? Link to comment Share on other sites More sharing options...
280z4me Posted December 9, 2008 Author Share #3 Posted December 9, 2008 Its a 76 280z Link to comment Share on other sites More sharing options...
sblake01 Posted December 9, 2008 Share #4 Posted December 9, 2008 Doubtful that the 'computer' is the problem. It's not really a computer per se like in a modern car but just a control unit. Regardless of what you hear they rarely fail unless they've been abused. Sounds like you need to familiarize yourself with the 'Engine Fuel' section of the Factory Service Manual. That way you'll understand a little more about the car and ask more informed questions which will lead to better answers. You can find a copy of it here:http://www.xenons30.com/files/FSM/76_datsun_280z.zip Link to comment Share on other sites More sharing options...
