Hi all
I'm out looking after pistons for my L24, i have sourced down a supplier with very interesting prices, they have 2 kind of flat tops, the one with valve relief's and the other without.
The seller say that the one without (Ry 2516) is for 70 - 72 and the one with relief's (RY 6335) is for 73.
My car is a 73, still i prefere pistons without relisf's
The only thing i can think could be the reason for the pistons having relief's is due to larger valves in the E88.
My question is, will the one without relief's work ? motor is bone stock, except of round top SU's and header, any input is appreciated.
Chris
Edited by ChrisZ
https://www.classiczcars.com/forums/topic/30237-flat-top-pistons/
I'm no expert on this, but it seems that if you're running a stock head with stock block, the reliefs are there for a reason. My flat-tops (70) have owner-induced "reliefs" imprinted due to a bad cam install I did years ago. I'd hate to think you'd do the same thing from a different source....
Frank
Deck is surfaced, but did Datsun ever come with relief's ?
I once heard that the relief's dont even match up with the valves, to me they are just less compression and more chance of detonation.
Dave a set is with pins and rings, price is $180 - 200 depending on model, http://www.coolparts.com/index.php?p=catalog&mode=search&search_in=all&search_str=ry+2516&x=0&y=0 you can look it up.
The car use to have reliefs in pistons, i just like to know if it is necessary or not.
Chris
Btw, Dave there is a thread about LED lights going on at HybridZ
