Posted December 15, 200816 yr comment_268992 I got my 5 speed out of the 79 ZX in that local boneyard. So now I can complete the R180 4.11/5-speed conversion. I can't wait to drive the car again in the Spring. Between the tranny/diff swap, the new rear struts and the new rear sway bar, I'll be looking for punks in Mustangs to run past. :classic: Apart from changing fluid, what should I do to the tranny before installing it? Its got about 65K on it, and it was driven to where it sits. The best part, I made the finals in my fantasy football league yesterday, which guarantees my at least $330, and up to $700. Cost of the 5 speed and the 4.11 R-180 package...$350. If I win the final this week, all of this Winters upgrades will be paid for by my buddies. Link to comment https://www.classiczcars.com/forums/topic/30259-got-my-5-speed/ Share on other sites More sharing options...
December 16, 200816 yr comment_269034 What a deal, you oughtta play the lottery while you are on a roll Link to comment https://www.classiczcars.com/forums/topic/30259-got-my-5-speed/#findComment-269034 Share on other sites More sharing options...
December 16, 200816 yr comment_269037 Weasel, I'd change out the seals (both front and rear). If the tranny has been sitting for a while, they are likely to be a trouble spot at some point in the future. Probably new shifter bushings as well. Link to comment https://www.classiczcars.com/forums/topic/30259-got-my-5-speed/#findComment-269037 Share on other sites More sharing options...
December 16, 200816 yr Author comment_269066 That's what I was thinking Arne. So I'll do the seals, fluids and the bushings. I also have to get the 22-tooth gear so my speedo works with the 4.11 diff. Anyone had luck heating/bending the 5-speed shifter so they fit in original 4-speed cars? Link to comment https://www.classiczcars.com/forums/topic/30259-got-my-5-speed/#findComment-269066 Share on other sites More sharing options...
December 16, 200816 yr comment_269088 Weasel, If your car is a '73 you can just use your old lever from the 4spd. That will actually make it a "shorter shifter". This is what I did and it works perfectly. I would get some new shifter bushings and you would be good to go. You can get a 22 tooth speedo cog from Zman of Washington www.zspecialties.com. Oliver is a good guy to work with and honest as the day is long.Cheers, Mike Edited December 16, 200816 yr by Pop's Z Link to comment https://www.classiczcars.com/forums/topic/30259-got-my-5-speed/#findComment-269088 Share on other sites More sharing options...
December 16, 200816 yr Author comment_269095 Weasel' date=' If your car is a '73 you can just use your old lever from the 4spd. That will actually make it a "shorter shifter". This is what I did and it works perfectly. I would get some new shifter bushings and you would be good to go. You can get a 22 tooth speedo cog from Zman of Washington [url']www.zspecialties.com. Oliver is a good guy to work with and honest as the day is long.Cheers, MikeI didn't realize that my 4-speed shifter would work. I actually replaced the original plastic bushings with CNC'd brass bushings this past Summer on the 4-speed, so it should be all set.Thanks for the speedo gear source. Link to comment https://www.classiczcars.com/forums/topic/30259-got-my-5-speed/#findComment-269095 Share on other sites More sharing options...
December 18, 200816 yr comment_269152 what do you needed for the trans. swap? the zx trans. fits in all z cars? Link to comment https://www.classiczcars.com/forums/topic/30259-got-my-5-speed/#findComment-269152 Share on other sites More sharing options...
December 18, 200816 yr Author comment_269176 what do you needed for the trans. swap? the zx trans. fits in all z cars?The ZX tranny's do bolt up, but I believe the Borg-Warner 5 speed (out of Turbo ZX's) requires some modifications. If you get a 5 speed from a 77 - 83 NA 280Z/ZX, it'll bolt right up, you just have to open up the hole in the tranny tunnel for the new shifter pattern. Link to comment https://www.classiczcars.com/forums/topic/30259-got-my-5-speed/#findComment-269176 Share on other sites More sharing options...
December 18, 200816 yr comment_269178 If you get a 5 speed from a 77 - 83 NA 280Z/ZX, it'll bolt right up, you just have to open up the hole in the tranny tunnel for the new shifter pattern.I thought that was only true on the early cars, i.e. the ones that were originally fitted with a type A trans. Link to comment https://www.classiczcars.com/forums/topic/30259-got-my-5-speed/#findComment-269178 Share on other sites More sharing options...
December 23, 200816 yr Author comment_269538 The best part, I made the finals in my fantasy football league yesterday, which guarantees my at least $330, and up to $700. Cost of the 5 speed and the 4.11 R-180 package...$350. If I win the final this week, all of this Winters upgrades will be paid for by my buddies. Just thought I'd update you guys...I won, BIG (155-117). Thanks to Antonio Bryant, Reggie Wayne and De'angelo Williams, all Winter 2008 upgrades paid for by my friends. :bandit: As far as the tranny tunnel thing...you'd certainly know better than me Stephen since this is my first Z. But I thought it was the case for all original 4-speeds. Edited December 23, 200816 yr by Weasel73240Z Link to comment https://www.classiczcars.com/forums/topic/30259-got-my-5-speed/#findComment-269538 Share on other sites More sharing options...
December 23, 200816 yr comment_269542 From what I understand, if you use the 77-78 shifter on any of the 5 speeds, you don't have to cut anything except in the earliest cars. Link to comment https://www.classiczcars.com/forums/topic/30259-got-my-5-speed/#findComment-269542 Share on other sites More sharing options...
