Posted December 15, 200816 yr comment_269003 Does anyone know what the 280ZX fuel pumps flows in terms of LPH or GPH. Im Installing megasquirt on my 260 and need to know how many GPH my lift pump needs to flow for my surge tank.Thanks Link to comment https://www.classiczcars.com/forums/topic/30261-fuel-pump-flow/ Share on other sites More sharing options...
December 15, 200816 yr comment_269007 are you aiming for performance? i.e. high hp? Link to comment https://www.classiczcars.com/forums/topic/30261-fuel-pump-flow/#findComment-269007 Share on other sites More sharing options...
December 16, 200816 yr comment_269033 I used one of these to fill a 2L surge tank. Carter LP fuel pump. If you uses a fairly large surge tank there will be that amount of fuel in reserve at all times for the HP pump to draw on. Use filters at the input and output of all pumps and they should last indefinitely barring electrical breakdown. Link to comment https://www.classiczcars.com/forums/topic/30261-fuel-pump-flow/#findComment-269033 Share on other sites More sharing options...
December 16, 200816 yr comment_269058 I use one of these on my Megasquirt controlled TWM system:http://store.summitracing.com/partdetail.asp?autofilter=1&part=HLY%2D12%2D920&N=700+4294925239+4294836965+115&autoview=sku Link to comment https://www.classiczcars.com/forums/topic/30261-fuel-pump-flow/#findComment-269058 Share on other sites More sharing options...
December 16, 200816 yr Author comment_269059 Im not looking for high HP I just want to run injection on a stock L26. Im planning on using a 280ZX fuel pump after the surge tank, I just need a pump to fill my surge tank. Link to comment https://www.classiczcars.com/forums/topic/30261-fuel-pump-flow/#findComment-269059 Share on other sites More sharing options...
