I used one of these to fill a 2L surge tank.
Carter LP fuel pump.
If you uses a fairly large surge tank there will be that amount of fuel in reserve at all times for the HP pump to draw on.
Use filters at the input and output of all pumps and they should last indefinitely barring electrical breakdown.
