Posted December 22, 200816 yr comment_269432 HOW OFTEN SHOULD THE VALVE BE ADJUSTED? THANKS FOR ANY HELP::classic: Link to comment https://www.classiczcars.com/forums/topic/30301-valve-adjustment/ Share on other sites More sharing options...
December 22, 200816 yr Author comment_269433 Valves !!!! Link to comment https://www.classiczcars.com/forums/topic/30301-valve-adjustment/#findComment-269433 Share on other sites More sharing options...
December 22, 200816 yr comment_269434 The service manual for a 240Z says to check and adjust them as needed every 6,000 miles.-Mike Link to comment https://www.classiczcars.com/forums/topic/30301-valve-adjustment/#findComment-269434 Share on other sites More sharing options...
December 22, 200816 yr Author comment_269435 Thanks alot,,, does anyone know the clearance specs for a 78 280 Link to comment https://www.classiczcars.com/forums/topic/30301-valve-adjustment/#findComment-269435 Share on other sites More sharing options...
December 22, 200816 yr comment_269436 If I recall correctly, the interval on my '71 & '72 called for adjustment of clearance every 6,000 miles. (I do it every spring just to keep in touch with the girl.)(edit) Ooops... Mike B beat me to it... Edited December 22, 200816 yr by DeesZ Link to comment https://www.classiczcars.com/forums/topic/30301-valve-adjustment/#findComment-269436 Share on other sites More sharing options...
December 22, 200816 yr comment_269437 The 280Z owners manual says to do the first adjustment at 1000 miles and every 12 months or 15000 miles thereafter. Keep in mind that this is for a new car so you can disreagard the first adjustment. Intake-.25mm(.0010") Exhaust .30mm(.0012")-Hot. Edited December 22, 200816 yr by sblake01 Link to comment https://www.classiczcars.com/forums/topic/30301-valve-adjustment/#findComment-269437 Share on other sites More sharing options...
December 23, 200816 yr comment_269497 Would the 1000 miles adjustment apply also to a rebuild engine? Link to comment https://www.classiczcars.com/forums/topic/30301-valve-adjustment/#findComment-269497 Share on other sites More sharing options...
December 23, 200816 yr comment_269498 Walter Moore said: Would the 1000 miles adjustment apply also to a rebuild engine?IMO, yes. Assuming it was a true rebuild with a valve job. In fact, on a rebuild I might do my first check at 500 miles, and then again at 1000. Link to comment https://www.classiczcars.com/forums/topic/30301-valve-adjustment/#findComment-269498 Share on other sites More sharing options...
