Posted December 28, 200816 yr comment_269757 Hi,Iam looking to add a elec fuel pump to my 72z but it doesnt come with factroy bracket. does any one have one?? Or an idea what it looks like. Thanks Steve Edited December 28, 200816 yr by steves72z spelling error Link to comment https://www.classiczcars.com/forums/topic/30347-elec-fuel-pump-bracket/ Share on other sites More sharing options...
December 31, 200816 yr comment_269911 I have the pump and bracket. I have att. some pics so you can see what it looks like and how the pump is attached. An L-shaped piece of steel or aluminum, approx. 6" X 4" with a 3" ell section would probably suffice. Link to comment https://www.classiczcars.com/forums/topic/30347-elec-fuel-pump-bracket/#findComment-269911 Share on other sites More sharing options...
December 31, 200816 yr comment_269918 I made mine from a length of 3/16''X 1''X 10'' strap of steel I bought at Home Depot. I just put two 90* bends in it and bolted it to the plate by the mustache bar . I used rubber mounts between the pump and bracket. You just need to make room for the mustache bar.Gary Link to comment https://www.classiczcars.com/forums/topic/30347-elec-fuel-pump-bracket/#findComment-269918 Share on other sites More sharing options...
December 31, 200816 yr comment_269923 Thanks George - I'd been looking for pictures of that pump and bracket for the past two days.. Knew I had them somewhere... but couldn't find them again...Anyone have pictures of the second type used on the late model 73 240-Z's and 260Z's?FWIW,Carl B. Link to comment https://www.classiczcars.com/forums/topic/30347-elec-fuel-pump-bracket/#findComment-269923 Share on other sites More sharing options...
December 31, 200816 yr comment_269929 Yup, I just rebuilt and finished mine a few weeks ago. It was all tangled and bent (previous owner issue) The black color makes the picture blend but I hope these help. Dave. The last 3 pics are obviously the before pictures... Edited December 31, 200816 yr by Zs-ondabrain Link to comment https://www.classiczcars.com/forums/topic/30347-elec-fuel-pump-bracket/#findComment-269929 Share on other sites More sharing options...
December 31, 200816 yr comment_269931 Wonderful !! - thanks Dave. Link to comment https://www.classiczcars.com/forums/topic/30347-elec-fuel-pump-bracket/#findComment-269931 Share on other sites More sharing options...
December 31, 200816 yr comment_269939 There is a paper filter inside the pump, is that other filter on Daves Z stock or did the previous owner install it? Link to comment https://www.classiczcars.com/forums/topic/30347-elec-fuel-pump-bracket/#findComment-269939 Share on other sites More sharing options...
December 31, 200816 yr comment_269968 That's a stock set-up for the 260Z (early) The paper filter cartridge is still in the fuel pump but I guess that's Nissans way of PreFiltering before the pump, since most people don't even know there is a filter Inside the pump.The filters are basically the same price but easier to to replace the white plastic one. Go figure.Dave.http://www.rockauto.com/catalog/raframecatalog.php?carcode=1209181&parttype=6200&a=FRc1209181k479057 Link to comment https://www.classiczcars.com/forums/topic/30347-elec-fuel-pump-bracket/#findComment-269968 Share on other sites More sharing options...
December 31, 200816 yr comment_269973 Check ebay, a new fuel pump bracket was listed today. not mine but thought you might be interested.Happy New Year to All Link to comment https://www.classiczcars.com/forums/topic/30347-elec-fuel-pump-bracket/#findComment-269973 Share on other sites More sharing options...
January 1, 200916 yr comment_269981 Here's some pictures of the fuel pump and bracket from my 5/73 240. DK Link to comment https://www.classiczcars.com/forums/topic/30347-elec-fuel-pump-bracket/#findComment-269981 Share on other sites More sharing options...
January 1, 200916 yr comment_269985 Here's some pictures of the fuel pump and bracket from my 5/73 240.DKWhat does it bolt to in the back? I used the 280Z fuel pump bracket in my 71 and two threaded mounting holes in the sub frame lined up with the bracket but for the other I had to drill and tap a spot in the subframe for the second bolt. The 280Z bracket looks like the one Dave has pictures of.I see that the guy selling the bracket on Ebay also has the fuel pump for sale.http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=180317539406&ssPageName=STRK:MEWA:IT&ih=008 Edited January 2, 200916 yr by Maples71240Z Link to comment https://www.classiczcars.com/forums/topic/30347-elec-fuel-pump-bracket/#findComment-269985 Share on other sites More sharing options...
January 1, 200916 yr comment_269995 That's a stock set-up for the 260Z (early) The paper filter cartridge is still in the fuel pump but I guess that's Nissans way of PreFiltering before the pump, since most people don't even know there is a filter Inside the pump.The filters are basically the same price but easier to to replace the white plastic one. Go figure.Dave.Is the spring clip fuel filter bracket the same one used in the engine bay? Link to comment https://www.classiczcars.com/forums/topic/30347-elec-fuel-pump-bracket/#findComment-269995 Share on other sites More sharing options...
