Posted December 30, 200816 yr comment_269864 I am trying to figure out the exact stock paint "plan" for an early series 1 engine. I would like to know what pulleys are painted blue, which ones are natural or plated, what adjusting arms are painted blue, which ones are left natural or plated cadmium, what color was the air pump inlet painted or plated, Fan clutch finish, etc.If anybody has all the details I would greatly appreciate the time spent to detail it here.Thank you! Link to comment https://www.classiczcars.com/forums/topic/30365-series-1-engine-paint-plan-details-please/ Share on other sites More sharing options...
December 30, 200816 yr comment_269871 I suggest you look for user 'kats' posts. He has a website which details his amazing restoration and has a lot of great photos and documentation. I'd give you the link, but I'm not at my place right now and don't have the bookmark. Link to comment https://www.classiczcars.com/forums/topic/30365-series-1-engine-paint-plan-details-please/#findComment-269871 Share on other sites More sharing options...
December 30, 200816 yr comment_269882 Here is one (I believe) Username Kats Website. http://www.geocities.jp/datsunz903/ You will need quite a bit of time to fully snoop around all the nooks and crannies. There is lots of great stuff here and Kats is #1 all around Good Guy! Tuck\o/ Link to comment https://www.classiczcars.com/forums/topic/30365-series-1-engine-paint-plan-details-please/#findComment-269882 Share on other sites More sharing options...
December 31, 200816 yr comment_269915 Kats' website is a great reference and he has some fascinating stuff posted. Let me see if I can be of further help. The block is, of course, blue. That paint can be purchased in spray cans from the manufacturer http://www.towerpaint.com/ or http://zzxdatsun.com/ or http://www.classicdatsun.com/ When the blocks were originally painted, they were assembled engines so original engines had a lot of overspray on parts that had other finishes. For instance, the head is normally natural aluminum but it has overspray blue next to the block. So it goes for engine mounts (black) and the heater hose fittings (cad plate) and the oil pan (black).The front damper pulley is blue and the nut is cad plated with overspray. The adjustment arm to hold the alternator is blue. I'm not certain because mine are restored black, but I think the alternator pulley and the fan blade for the alternator are cad plate. The alternator casing is natural aluminum and be aware that the early alternators were what we call the grapefuit type. The end plate is silver zinc plate with overspray. The front timing cover is natural aluminum (with overspray). The fan clutch is natural aluminum and the metal type fan is cream white. The air pump is a mixture of blue and natural aluminum with the pulley cad plate. Bolts and fittings were all cad plate but depending on location may be painted to match the surrounding part. Point being that Nissan did not build "bling" engines as we see so commonly in show cars. They were mass assembled and painted with little regard to masking - overspray is common. Let me dig for pictures as I am going from memory at the moment. Link to comment https://www.classiczcars.com/forums/topic/30365-series-1-engine-paint-plan-details-please/#findComment-269915 Share on other sites More sharing options...
December 31, 200816 yr comment_269916 Hope these help Link to comment https://www.classiczcars.com/forums/topic/30365-series-1-engine-paint-plan-details-please/#findComment-269916 Share on other sites More sharing options...
December 31, 200816 yr Author comment_269920 Great info 26th. The pictures Kats provides are good but not as detailed as you explain. I am going to order paint tomorrow. Any preference on vendor? I noticed that one vendor is about $10 cheaper per can.Thanks, John Link to comment https://www.classiczcars.com/forums/topic/30365-series-1-engine-paint-plan-details-please/#findComment-269920 Share on other sites More sharing options...
December 31, 200816 yr comment_269924 The air pump is a mixture of blue and natural aluminum with the pulley cad plate.Chris, this is probably what you meant, but the air pump pulley is painted blue engine color and fastened to cad plated pump drive wheel with cad plated fasteners, all yellow cad, I believe. Dan Link to comment https://www.classiczcars.com/forums/topic/30365-series-1-engine-paint-plan-details-please/#findComment-269924 Share on other sites More sharing options...
December 31, 200816 yr comment_269930 Les at Classic datsun was the first to offer this, it should be the correct mix, the engine paint color is a left over from the time when the Japs was assembling engines for the Brits, so i wouldnt be surpriced if VB have it.Chris Link to comment https://www.classiczcars.com/forums/topic/30365-series-1-engine-paint-plan-details-please/#findComment-269930 Share on other sites More sharing options...
December 31, 200816 yr comment_269941 Les has the stuff you need for series 1. Johnny'O...... $10 savings on the engine paint? Plan on spending your life savings for a series 1 resto Link to comment https://www.classiczcars.com/forums/topic/30365-series-1-engine-paint-plan-details-please/#findComment-269941 Share on other sites More sharing options...
January 1, 200916 yr comment_269992 26th-Z said, "The adjustment arm to hold the alternator is blue."I can confirm this. The arm and alt. on mine was replaced in 1980 during the engine rebuild. It is blue, has the part number sticker and my name and date taped to it. The new alt. has the cad plate pully and fan blades.Bonzi Lon Link to comment https://www.classiczcars.com/forums/topic/30365-series-1-engine-paint-plan-details-please/#findComment-269992 Share on other sites More sharing options...
January 1, 200916 yr Author comment_270011 Johnny'O...... $10 savings on the engine paint? Plan on spending your life savings for a series 1 resto That's why I try to save where I can. I don't have much of a life savings! Link to comment https://www.classiczcars.com/forums/topic/30365-series-1-engine-paint-plan-details-please/#findComment-270011 Share on other sites More sharing options...
January 1, 200916 yr Author comment_270012 Thanks again for all the info. My alt adjusting arm is blue. I will blast and repaint it the true blue when I order it from Les. I think I have enough to get started. Thanks all! Link to comment https://www.classiczcars.com/forums/topic/30365-series-1-engine-paint-plan-details-please/#findComment-270012 Share on other sites More sharing options...
