Posted January 1, 200916 yr comment_269975 i just joined this forum. i just purchased a 1976 280z. the car has 110,000 miles on it. it has been sitting 1-2 years. it minor rust except behind right rear wheel where it is kind of bad. what are the main things i need to be aware of?what should i immediately do to the engine (manual trans) in regards to tuning-up?any and all information will be greatly appreciated.shane ishmael Link to comment https://www.classiczcars.com/forums/topic/30382-need-info-on-76-280z/ Share on other sites More sharing options...
January 1, 200916 yr comment_269977 Welcome, Shane. Here's a link to a thread that should help you, even though your car is fuel-injected. Post #8 by Carl Beck is particularly helpful and informative. YOu may want to do a search to find more info on fuel-injected cars. http://www.classiczcars.com/forums/showthread.php?t=22619 Edited January 1, 200916 yr by lonetreesteve Link to comment https://www.classiczcars.com/forums/topic/30382-need-info-on-76-280z/#findComment-269977 Share on other sites More sharing options...
January 3, 200916 yr comment_270127 Shane,Welcome!Follow this link for the most comprehensive fuel injected classic Z help site:http://www.atlanticz.ca/component/option,com_wrapper/Itemid,30/ Link to comment https://www.classiczcars.com/forums/topic/30382-need-info-on-76-280z/#findComment-270127 Share on other sites More sharing options...
January 3, 200916 yr comment_270135 Welcome! Here's two useful links for you. They're both for the 1976 280 Factory Service Manual. IMO, the factory service manuals are the best technical resource especially for the fuel injected S30. Use this link if you have WinZip: http://www.xenons30.com/files/FSM/76_datsun_280z.zip and this one if you don't: http://www.nicoclub.com/FSM/280z/1976/ both will ultimately require the use of the Adobe Acrobat Reader or Adobe Acrobat Professional. Link to comment https://www.classiczcars.com/forums/topic/30382-need-info-on-76-280z/#findComment-270135 Share on other sites More sharing options...
