July 8, 200519 yr comment_129952 Quote You can still get it but just go Direct from Arizona ZCar its the same kit. Im sure its not the same kit, as Dave at ArizonaZcar.com does not sell his kit to any other suppliers, he designs the entire system and has every part made to complete the conversion, everything is perfect I have 2 Zcars with his Wilwood kit and they both rock the house. heres a few photos. BTW thats his new coilover kit and Chromoly rear control arms and billet mustache bar if you look close. Oh those are behind 9inch wide 17's on the rear http://img214.echo.cx/img214/8520/cimg34166zy.jpg Front brakes behind wheel http://img136.echo.cx/img136/940/cimg34239io.jpg rear brakes behind wheel http://img56.echo.cx/img56/9864/cimg34181zp.jpg front long shot http://img159.echo.cx/img159/2995/cimg35074go.jpg Link to comment https://www.classiczcars.com/forums/topic/304-rear-disc-conversion/?&page=2#findComment-129952 Share on other sites More sharing options...
July 8, 200519 yr comment_129953 That's a nice looking setup on a nice looking Z. Can you tell us what year? Welcome to the club by the way. Chris Link to comment https://www.classiczcars.com/forums/topic/304-rear-disc-conversion/?&page=2#findComment-129953 Share on other sites More sharing options...
July 8, 200519 yr comment_129964 Mike said: Eric Chapman made a conversion kit for the early Zcar for disc brakes. I researched this heavily and was able to talk with him on the phone. The following are notes from a conversation that I had with him.Questions for Eric Chapman’s Rear Disc Setup:What is included in the kit?2 brackets and bolts that hold calipers to bracketWhat else will I need to purchase?280zx – 79 thru 81 calipers, rotors, & master cylinder (240z not compatible but, not strong enough)What year discs to use?See aboveHow do they fit? Over the existing spindle?Bolt right on spindle.Take drum brake cover off.His bracket bolts on to brake cover 4-bolt pattern. Use lock-tite.Remount spindle.Will my existing system remain unharmed and unmodified?yeaWhat calipers to buy? Year? Nissan wants $350/eaGet ‘em from junkyard. Try to find some that are good looking shape. Minimal rust. Look at dust seal. If it’s good, get it. If it’s leaking, don’t do it.Toyota 4-piston calipers?Too much brake for the rear. Not compatible. It will make your rear-end lock up.How does the emergency brake connect?Connects up just fine.Flip cables at junction to shorten them.Doesn’t affect operation.Do I have to modify master cylinder?No, get 280zx unitNopi auto parts (turbo mag) huge import place 800-277-6674Tell ‘em z-car clubDo I have to modify hydraulic braking system at all?Remove the pressure switch under the master cylinder.Any modifications by me such as welding or sawing required?noDo you have any recommendations for part manufacturers?Wheel bearingsBuy stockSKF are good tooNSK are very very good… add more balls to bearing.Brake padsCall NopiLucas Gurling (maybe called Axis now)I decided to remain stock. If you have a lot of cash and time this might be a good conversion. But, I didn't want to mess with my master cylinder or deal with braking issues. Of course, I did a whole new restoration, so I wanted to put my money in other places.[m]I guess I'm a little late for this thread :stupid: but I did have the setup you were talking about so long ago Mike. This was Eric's setup that was sold under the name ZQuip. There was a write up about it in Z-Car Magazine's very first issue. Used 79-81 Calipers and rotors. The kit did indeed include the caliper brackets and the bolts. The bracket was a circle, didn't need to be. You could easily cut part of the bracket away and bolt it up with 3 bolts and it would be fine. I realized this later, but at the time when it was installed I pulled the stub axle to mount the bracket. On mine the rears worked great with the stock front calipers, but when I went to 4x4 calipers I couldn't get any rear braking. The big 79-81 calipers are supposed to be more reliable than the later 82-83 calipers, and I never had any trouble with mine in the 8 years I had them on the car. I ran it with a 240SX ebrake cable and removed the front bell crank and attached the ebrake handle directly to the cable end. This setup worked fine, just couldn't handle the hard braking I was doing on slicks, so I ended up with the JSK/Wilwood brakes, very similar to 2fiddyZ's. Link to comment https://www.classiczcars.com/forums/topic/304-rear-disc-conversion/?&page=2#findComment-129964 Share on other sites More sharing options...
July 21, 200519 yr comment_131352 i believe i bought that set up from jmortensen ... back in june or july of ought four ... it's still boxed up in my garage, i never opened it ... haven't gotten around to installing it after having the rug yanked out from under me when the body shop was sold right in the middle of body and paint ... i have been wasting my money and time engineering on the fly ... getting that taurus 2 spd fan installed ...i figure on installing the rear discs once i get the z running again ... mostly for the oh wow factor ... and i'm tired of messing with rear drums. as most know, there really is no reason to install rear discs on the 240z. the stock drums and the green shoes work fine. discs just cool off faster, thus less brake fade with multiple panic stops, or very spirited mountain driving ... no reason for cross drilled or slotted discs ... the high temps that occur under the extreme torture of the race track causes the pads to out gas when they get hot. 99% of street cars will not reach those temps. the slots or cross drilled holes are to release those gases, so the pads make contact with the rotors. vented rotors are the ones, if one stood a quarter on edge, all those ridges .... if it were a brake rotor ... those ridges would be the vents. yes, they do help to cool the rotors. if one uses the 280zx master, there should be no reason to remove any residual valves ... the zx's have rear discs. if using the stock 240z master, yes you need to remove that check valve at the master. either way, you will also have to remove the check valve at the rear of the 240z. it would be a good idea to install a proportioning valve, so the rears don't lock before the fronts ... too much rear bias, rear wheels lock up and want to swing around past the front of the car ... once you get the hang of it, probably be loads of fun. i would imagine the first 5 or 6 times, til you got used to it, you'd be on the side of the road, cleaning your thong out ... i wonder if after over a year of sitting if the calipers are still good ??? i'm thinking they should be fine. here's what info i still have from mike squared aka brokebolthappy hunting, wayne Big rear brake conversion240sx 4 x 4 1/2 lugs79-81 280zx master 15/1689-98 240sx calipers and hangers84-85 300zx rear rotors 4x4 1/2 lug pattern86-80 FWD maxima rear dust shields and hub brackets both bored, cut and welded with correct offset.rear axles must be removed to install bracketsmake brake cable extenders Small rear brake conversion79-81 280zx master 15/1682-53 280zx rear calipers and hangers82-83 280zx rear rotors86-89 FWD maxima rear dust shields and hub brackets ... cut and welded with correct off setOR 80-84 nissan 810, maxima sedan rear brackets that have floating dust shieldrear axle must be removed to install bracketBig rear brake conversion 280zx79-81 280zx master 15/1682-83 280zx calipers and hangers84-85 300zx rear rotors 4 x 4 1/2 lugs86-89 FWD maxima rear dust shields and hub brackets ... bored cut and welded with correct off setbone stock small rear brake conversion Maxima 4x4 1/2 lugs79-81 280zx master 15/1679-81 280zx rear calipers and hangers79-81 280zx rotors 4x4 1/2 lugs80-84 810, maxima sedan rear brackets that have screw on dust shieldsrear axles must be pulled on all to install brackets Link to comment https://www.classiczcars.com/forums/topic/304-rear-disc-conversion/?&page=2#findComment-131352 Share on other sites More sharing options...
July 21, 200519 yr comment_131403 waynekarnes said: i wonder if after over a year of sitting if the calipers are still good ??? i'm thinking they should be fine. I'm sure they'll be fine. Link to comment https://www.classiczcars.com/forums/topic/304-rear-disc-conversion/?&page=2#findComment-131403 Share on other sites More sharing options...
July 21, 200519 yr comment_131484 thanks J ... that's my thinking too ... Link to comment https://www.classiczcars.com/forums/topic/304-rear-disc-conversion/?&page=2#findComment-131484 Share on other sites More sharing options...
July 22, 200519 yr comment_131495 Here's a nice detailed thread of why not to use 280zx rear disk conversion:http://forums.hybridz.org/showthread.php?t=82790&highlight=rear+disk+rebuildhttp://forums.hybridz.org/showthread.php?t=69575&highlight=280zx+caliper+adjustmentapparently for constant periodic readjustment required, some failures...food for thought Link to comment https://www.classiczcars.com/forums/topic/304-rear-disc-conversion/?&page=2#findComment-131495 Share on other sites More sharing options...
July 22, 200519 yr comment_131511 Just to clarify Alex, that's the LATER style 82-83. Early style doesn't have those problems, but the caliper is much bigger and heavier and the pads are actually smaller.Also of interest, if you look at the later ZX caliper vs 240SX caliper looks damn near identical to me. Haven't heard of a bunch of frozen SX calipers yet... Link to comment https://www.classiczcars.com/forums/topic/304-rear-disc-conversion/?&page=2#findComment-131511 Share on other sites More sharing options...
July 30, 200519 yr comment_132506 2fiddyz said: Im sure its not the same kit, as Dave at ArizonaZcar.com does not sell his kit to any other suppliers, he designs the entire system and has every part made to complete the conversion, everything is perfect I have 2 Zcars with his Wilwood kit and they both rock the house. heres a few photos. BTW thats his new coilover kit and Chromoly rear control arms and billet mustache bar if you look close. Oh those are behind 9inch wide 17's on the rear http://img214.echo.cx/img214/8520/cimg34166zy.jpg Front brakes behind wheel http://img136.echo.cx/img136/940/cimg34239io.jpg rear brakes behind wheel http://img56.echo.cx/img56/9864/cimg34181zp.jpg front long shot http://img159.echo.cx/img159/2995/cimg35074go.jpg what brand rims are those? what size tires are those front and rear? nice looking car by the way Link to comment https://www.classiczcars.com/forums/topic/304-rear-disc-conversion/?&page=2#findComment-132506 Share on other sites More sharing options...
August 23, 200519 yr comment_135394 They Look To Be 5zigen Fn01rc Off Of A S14 240sx/silvia. Link to comment https://www.classiczcars.com/forums/topic/304-rear-disc-conversion/?&page=2#findComment-135394 Share on other sites More sharing options...
December 21, 200519 yr comment_149664 Quote PROJECTRB240SX They Look To Be 5zigen Fn01rc Off Of A S14 240sx/silvia. They are FN01RC's 17x8 25mm in front and 17x9 35mm in the rear. Since they are aftermarket and different widths and offsets I dont think you can say they really came off of an "S" body. I bought them new. Great price for the weight. I am very happy with them. Quote That's a nice looking setup on a nice looking Z. Can you tell us what year? Welcome to the club by the way.Oh and its a 4 of 1971 manufacture date, and Thanks Quote waynekarnesas most know, there really is no reason to install rear discs on the 240z. the stock drums and the green shoes work fine. Until you have more than 3 times the rear wheel horsepower the car came with stock. I have probably more than 450 RWHP with my current setup at 21 PSI. You shoulda seen the look on the GSXR1000's owners face when I beat him in a roll on from 40-140, hell I was even surprised. Link to comment https://www.classiczcars.com/forums/topic/304-rear-disc-conversion/?&page=2#findComment-149664 Share on other sites More sharing options...
