lights out
refman1970
Start checking all your grounds. And check the connections at the switches, in the steering column area. The headlights and parking lights are 2 seperate systems so that tells me it's a supply or ground issue.
Dave.
One other thing, your post will be read. but it's not a good idea to ask the same question in multiple threads. Just FYI.
Edited by Zs-ondabrain
Just clean the clip and replace the fuse (make sure that you do the right one) it's just to easy to do not to try it. If the other lights did work, and now they don't (for no apparent reason). I'd bet on the fuses.
It was my problem (it was actually just so dirty it lost continuity)... Before I replaced the fuse, I'm not so happy to say that I must have traced every wire/ground/ connector in the entire car. My wiring is great now! :)
