We Need Your Help! ×
atmospheric superchage
r brown
This question was asked about a month ago and it still is a bunch of hot air.. Supercharging by any method is to induce fuel / air mixture under pressure into the cylinders . Only done by a blower , otherwise known ans a supercharger which is belt or gear driven, or a turbo charger which driven by a turbine revolved by the use of the exhoust gasses leaving the engine. there have been so called superchargers offered in the back of magazines for years some were little fan type things that were mounted under the carb that were suposed to spin when the air fuel mixture passed , that was one kind that was selling about 30 years ago . There have been several variatons of this around for y ears . Like the man said " there is a sucker born every min. " Any type of vaine or propeller of fan is a restriction to air flow and can not pressureise or increase air flow unless it is driven by some method that will INCRESE THE FLOW AND PUSH THE MIXTURE UNDER PRESSURE . Save your $$$
