Adding a radiator overflow tank
Noddle
Hi,
another easy DIY,
I brought this from Super Cheap ($15), it's a perfect fit, no screws needed, it just sort of 'clips into place'
make sure you get a sealed type of radiator cap ($8), so the water sucks back into the radiator when it cools.
Nigel
good find! that is nice and compact!
out of interest, what is the t piece on the sensor for? is that your oil sensor?
It's for my turbo conversion, I will run a steel line (maybe brake line), I don't like the flexi lines myself,
I'll do a write up on it, once I start, I'm still chasing bits.
Nigel
