i Have a 78 280z with a 5 speed. the the car stalls and dosnt move in Reverse and it moves forward in nuetral. im pulling the trans tomorrow dose anyone have any idea what is wrong? also can i put a 4 speed trans in instead and if so what type of modifucations will i have to make? thanks in advance.
https://www.classiczcars.com/forums/topic/30485-transmission-blown/
the car runs in 2nd, 3rd, 4th ,5th. not sure why its stalling but no matter how much throttle u give it it stalls if u dont engage the clutch or bring it out of reverse. it gose into gears alittle hard and its a littile stiff in nuetral.
Edited by rebelgt
missed answer to question
Is the clutch disengaging/engaging properly? I had a problem with reverse when I had a leaky clutch slave cylinder. But sounds more like transmission always good to check the simply things before pulling the entire transmission :)
Still the problem with reverse?
The shifter being hard to move now after replacing the slave would seem to indicate to me that the clutch is not disengaging, but I am in no way an expert far from it actually. Try bleeding the system again and ensure that there is enough throw on the new slave to fully disengage the clutch. If i remember correctly there are 2 types of slaves one that is adjustable on the early 240z series 1 cars and the non adjustable type that replaced it.
hey i blead the system again and it still will stall in reverse wont go in 3rd or 4th and goes foreward in nuetral i just started pulling the trans.
Sounds to me like a selector fork problem. The roll pins in the selectors have been known to break causing the tranny trying to get two gears at a time.
