Posted January 11, 200916 yr comment_270887 i Have a 78 280z with a 5 speed. the the car stalls and dosnt move in Reverse and it moves forward in nuetral. im pulling the trans tomorrow dose anyone have any idea what is wrong? also can i put a 4 speed trans in instead and if so what type of modifucations will i have to make? thanks in advance. Link to comment https://www.classiczcars.com/forums/topic/30485-transmission-blown/ Share on other sites More sharing options...
January 11, 200916 yr comment_270891 Does the car move in any other gear? Problems getting the transmission into gear? What causes the car to stall in reverse? The 4 spd will go in, but you may find the gearing unfavorable. Link to comment https://www.classiczcars.com/forums/topic/30485-transmission-blown/#findComment-270891 Share on other sites More sharing options...
January 11, 200916 yr Author comment_270892 the car runs in 2nd, 3rd, 4th ,5th. not sure why its stalling but no matter how much throttle u give it it stalls if u dont engage the clutch or bring it out of reverse. it gose into gears alittle hard and its a littile stiff in nuetral. Edited January 11, 200916 yr by rebelgt missed answer to question Link to comment https://www.classiczcars.com/forums/topic/30485-transmission-blown/#findComment-270892 Share on other sites More sharing options...
January 11, 200916 yr comment_270894 So it wont move then in reverse or first? Can a gear freeze like that without the other gears freezing? Strange. Is there oil in the tranny? Link to comment https://www.classiczcars.com/forums/topic/30485-transmission-blown/#findComment-270894 Share on other sites More sharing options...
January 11, 200916 yr comment_270895 Is the clutch disengaging/engaging properly? I had a problem with reverse when I had a leaky clutch slave cylinder. But sounds more like transmission always good to check the simply things before pulling the entire transmission Link to comment https://www.classiczcars.com/forums/topic/30485-transmission-blown/#findComment-270895 Share on other sites More sharing options...
January 12, 200916 yr Author comment_270983 i just replace the slave cylinder and blead the system. the trans wont go into 3rd or 4th anymore. and the shifter is hard to move Link to comment https://www.classiczcars.com/forums/topic/30485-transmission-blown/#findComment-270983 Share on other sites More sharing options...
January 12, 200916 yr comment_270989 Still the problem with reverse?The shifter being hard to move now after replacing the slave would seem to indicate to me that the clutch is not disengaging, but I am in no way an expert far from it actually. Try bleeding the system again and ensure that there is enough throw on the new slave to fully disengage the clutch. If i remember correctly there are 2 types of slaves one that is adjustable on the early 240z series 1 cars and the non adjustable type that replaced it. Link to comment https://www.classiczcars.com/forums/topic/30485-transmission-blown/#findComment-270989 Share on other sites More sharing options...
January 14, 200916 yr Author comment_271152 hey i blead the system again and it still will stall in reverse wont go in 3rd or 4th and goes foreward in nuetral i just started pulling the trans. Link to comment https://www.classiczcars.com/forums/topic/30485-transmission-blown/#findComment-271152 Share on other sites More sharing options...
January 14, 200916 yr comment_271164 Ok good luck, always good to try the easy stuff first. Sorry I could not be more help Link to comment https://www.classiczcars.com/forums/topic/30485-transmission-blown/#findComment-271164 Share on other sites More sharing options...
January 14, 200916 yr comment_271184 You can get a full transmission rebuild kit for under $200. I've got a link on my home computer, i'll post it later. I also have a link to a sweet rebuild instruction page Link to comment https://www.classiczcars.com/forums/topic/30485-transmission-blown/#findComment-271184 Share on other sites More sharing options...
January 15, 200916 yr comment_271223 hey i blead the system again and it still will stall in reverse wont go in 3rd or 4th and goes foreward in nuetral i just started pulling the trans.Sounds to me like a selector fork problem. The roll pins in the selectors have been known to break causing the tranny trying to get two gears at a time. Link to comment https://www.classiczcars.com/forums/topic/30485-transmission-blown/#findComment-271223 Share on other sites More sharing options...
January 15, 200916 yr comment_271241 here's the link to the rebuild kithttp://www.drivetrain.com/nissian4_5sprwd.htmland how to do it...http://www.atlanticz.ca/zclub/techtips/transmissionbreakdown/index.htmltake lots of pics, and post them! Link to comment https://www.classiczcars.com/forums/topic/30485-transmission-blown/#findComment-271241 Share on other sites More sharing options...
