It is raining and cold(for South Georgia anyway) here now. When it stops raining, I'll head out to the trailer and snap a pic or two of the nos parts(and numbers) for you.
As I said earlier, you can get the grills from the dealer, if you seal theupper and lower hatch openings, that is all you need for the right look-and you avoid the possibility of exhaust being drawn into the cockpit.
Ebay has the other parts you need on occassion, but be careful, they effectively crumble with age, what looks great in a picture can fall apart in your hands.
Will
As I said earlier, you can get the grills from the dealer, if you seal the upper and lower hatch openings, that is all you need for the right look-and you avoid the possibility of exhaust being drawn into the cockpit.Will
Thanks Will. Yes, all I want is the "right look"...Robert
Will, how would you go about sealing the openings for the hatch vents? I have a decent quality vent (part #90820-e4100) but always concerned about exhaust concerns.
Another question: how would you insulate around the hatch latch so exhaust wouldn't get in?
I am analyzing all exhaust leak options and any answers regarding the hatch would be appreciated!
Thanks!
Thanks!
For the vents, I am using a gasket I made from adhesive backed neoprene foam to seal the vent plenum to the inside of the hatch.
I am using pretty much the same thing on the lock mechanism-a sheet of the same neoprene sealing behind the mechanism.
Will
