Posted January 14, 200916 yr comment_271123 hey i thought i would post here as well. story goes... i got a car that was half done by the PO and now i have no bolts to hold the seats down. Does anybody know what size bolts i need to do this?The car is a 1972 240z.also posted here http://www.classiczcars.com/forums/showthread.php?t=33084 Link to comment https://www.classiczcars.com/forums/topic/30513-help-need-seat-mounting-bolt-size/ Share on other sites More sharing options...
January 14, 200916 yr Author comment_271125 I found the answer after searching the forums for a while, just in case your intrested, heres the answer... Credits to montoya_fan01.."Seat mount bolt size is 8mm x 1.25, with an 8mm JIS nut which requires a 12mm hex wrench.Bolts are sized by diameter of threaded portion and thread pitch, then length of bolt. example: 8mm x 1.25 x 25mm The hex size is not used to identify the size of a bolt or nut."Thanks buddy! Link to comment https://www.classiczcars.com/forums/topic/30513-help-need-seat-mounting-bolt-size/#findComment-271125 Share on other sites More sharing options...
