71 'Z' Dome Light removal?
peng155
Hi Guy's...
I'm sure this it's pretty simple.. BUT can someone tell me how to remove the dome light in a 71 'Z'?
I went through my manuals, but nada on how to remove it, I need to take mine out and see if the push switch is broke. the push to manually turn on, Push to turn off doesn't work any more.. I use to feel it click on, and off... not anymore.
MSA wants 60 bucks for a new one, so I thought I'd see if I can fix this one before I buy a new one.
Thanks
There are 2 plastic tabs on each long side of the dome light. you should be able to wiggle them lose enough to pull the assembly out. It's usually pretty easy due to the fact that it needs to come out to change the bulb out.
Ignore the circuit board where a bulb should be. And look near my palm to see the 2 tabs I was refering to,
Dave.
Edited by Zs-ondabrain
  • Who's Online   2 Members, 0 Anonymous, 557 Guests (See full list)
