Posted September 19, 200222 yr comment_15908 I have gone to multiple auto parts store and cannot find high heat sealant. Where do you find this item and what is its' maximum temperature rating? Link to comment https://www.classiczcars.com/forums/topic/3058-copper-high-heat-sealant/ Share on other sites More sharing options...
September 19, 200222 yr comment_15913 Hmm, last time I was at the Advance store they had the Permatex high heat copper in an aerosol can. Wonder why you can't find it? It should be something easy to find. Link to comment https://www.classiczcars.com/forums/topic/3058-copper-high-heat-sealant/#findComment-15913 Share on other sites More sharing options...
September 19, 200222 yr comment_15935 I've seen it at most automotive parts stores. They ususally keep it with the other silicone sealant's. The temp rating should be on the tube. Link to comment https://www.classiczcars.com/forums/topic/3058-copper-high-heat-sealant/#findComment-15935 Share on other sites More sharing options...
September 20, 200222 yr Author comment_15987 The highest temp. rated sealant that I have found is 650 deg. f. I believe that an exhaust manifold temp would exceed 650 . Link to comment https://www.classiczcars.com/forums/topic/3058-copper-high-heat-sealant/#findComment-15987 Share on other sites More sharing options...
September 20, 200222 yr comment_15990 Look at POR-15's Fire Seal 2000. Made for sealing up manifolds goes up to 2000F.http://www.por15.com/puttys.html Link to comment https://www.classiczcars.com/forums/topic/3058-copper-high-heat-sealant/#findComment-15990 Share on other sites More sharing options...
