I was wondering if anyone could lend a hand with some road racing knowledge. I am getting ready to race a 76 280z. Do I stick with the stock front suspension settings or does anyone know what a good baseline race setting would be ie: caster/camber, toe-in toe-out. Any info would be very appreciated. Thanks
^^^^ What he said :)
You forgot the most important question Chris, How much $$$$ have you got :stupid:and use that as a baseline to figure out how fast you want to go.
J/K Seriously, what are you going to be doing with the Z? Is it dual purpose? Street Driven? lots of variables that require a little more info before trying to help you make some good choices on set-up.
Paul
What ever category you will run in read the rule book make sure the modifications are within the rules. be ashamed to spend money in some neat stuff only to take out afterward. Good Luck
