Posted January 30, 200916 yr comment_272571 Can a 280z console fit a 240Z?Thanks. Link to comment https://www.classiczcars.com/forums/topic/30664-280z-console-in-a-240z/ Share on other sites More sharing options...
January 30, 200916 yr comment_272574 The 'off to top of my head' answer is no. Not without modification. You'd run into issues where it meets the dash right off the bat but I'm sure you'd run into others. Link to comment https://www.classiczcars.com/forums/topic/30664-280z-console-in-a-240z/#findComment-272574 Share on other sites More sharing options...
January 30, 200916 yr Author comment_272577 Thank You Stephen. Link to comment https://www.classiczcars.com/forums/topic/30664-280z-console-in-a-240z/#findComment-272577 Share on other sites More sharing options...
January 31, 200916 yr Author comment_272693 what about 75-76 vs 77-78 console? Are they the same...? Link to comment https://www.classiczcars.com/forums/topic/30664-280z-console-in-a-240z/#findComment-272693 Share on other sites More sharing options...
February 1, 200916 yr comment_272729 Pretty sure they're interchangable. The early ones, 75-76, didn't have a lid on the consle box. Link to comment https://www.classiczcars.com/forums/topic/30664-280z-console-in-a-240z/#findComment-272729 Share on other sites More sharing options...
July 31, 200915 yr comment_290843 hmmm, how about a 240 and the early 260 Link to comment https://www.classiczcars.com/forums/topic/30664-280z-console-in-a-240z/#findComment-290843 Share on other sites More sharing options...
July 31, 200915 yr comment_290855 No...74-78 will all fit (interchangable) but nothing will fit a 240 but a 240 because of the center dash connection.Mike Link to comment https://www.classiczcars.com/forums/topic/30664-280z-console-in-a-240z/#findComment-290855 Share on other sites More sharing options...
July 31, 200915 yr comment_290856 clayton 260z said: No...74-78 will all fit (interchangable) but nothing will fit a 240 but a 240 because of the center dash connection.MikeAdditionally, there are differences in the shifter location between the early ('70-71) and late ('72-73) styles for 240Z. Swapping between early and late styles on a 240Z may require mods in this area. I think (but don't take this as gospel) that the later style will fit all 240Z, but the early will not fit the later without some trimming. Link to comment https://www.classiczcars.com/forums/topic/30664-280z-console-in-a-240z/#findComment-290856 Share on other sites More sharing options...
