May 4, 200915 yr Author comment_282572 Concur Arne. I just went and looked where my holes should be in my cross member. I did find two through holes, and one with a nut plate in back, but nothing regular. Arne, did you say you only bolted yours up to your lower valance panels, vs the radiator lower support. I have a little while to figure this out, as I have some POR work to do, but I am hoping by next weekend I can be bolting things back up.Plus I have the little dilemma of not having half the bolts I need. THe nut plates on the center valance and where the left and left and right valance attach to the bezel are a smaller hole than the nut plates I have going into the fender. So I need to figure out what size they are and pick up about 12. Then once I get all the valances mounted rigid, I can fit the spook. I have about a dozen soft jaws for when I make furniture I can use to hold it while I measure. I certainly appreciate your help. Link to comment https://www.classiczcars.com/forums/topic/30667-front-end-spook-options/?&page=8#findComment-282572 Share on other sites More sharing options...
May 4, 200915 yr comment_282587 Yes, mine is currently attached only to the valance itself, not the core support. I still fiddle with that when I remove the spook periodically (bug cleaning and waxing). Still can't say that I have finalized mine quite yet. Link to comment https://www.classiczcars.com/forums/topic/30667-front-end-spook-options/?&page=8#findComment-282587 Share on other sites More sharing options...
May 4, 200915 yr comment_282590 Hi Arne:hummmm..... When I was at Les's shop around 1999 - he had just begun to reproduce the Spooks.. I bought four of them because I was so happy to get high quality reproductions, rather than having to rebuild mine for the fifth or sixth time. Plus I knew some of the guys around here would want or need one sooner or later, and Les needed to move a few to pay for the initial costs of startup..Anyway - I still had one on the shelf. I went out and took a look and sure enough the circles that indicate where to drill for the core support are clearly present. I'll see if I can get a clear picture tomorrow with some indirect sunlight. {hard to get clear picture of an all shinny black surface with a flash}.Even in 71, in order to get that first couple of bolts threaded into the captive nuts - one had to push up with one's right hand with a lot of pressure - and start the bolt on its way in with your left hand. Just holding the Spook in place - it is about 0.5" of more below the core support. As it is flexed up and the three bolts are tightened down - it spreads out to the sides a bit as well.Not knowing much about the design of fiberglass structures, I don't know if this pre-stress is intentional or not. I do know that the original held up on my Z without showing any stress cracks etc - at least until I destroyed it on parking stops..Like I said - that was around 99 - so things might have changed since then..FWIW,Carl B Link to comment https://www.classiczcars.com/forums/topic/30667-front-end-spook-options/?&page=8#findComment-282590 Share on other sites More sharing options...
May 4, 200915 yr Author comment_282595 You bring up an interesting point Carl, start from the center first, like applying vinyl decals, and work your way to the corners. Good point, and probably worth highlighting. Link to comment https://www.classiczcars.com/forums/topic/30667-front-end-spook-options/?&page=8#findComment-282595 Share on other sites More sharing options...
May 4, 200915 yr comment_282606 Hi Arne:hummmm..... When I was at Les's shop around 1999 - he had just begun to reproduce the Spooks.. I bought four of them because I was so happy to get high quality reproductions, rather than having to rebuild mine for the fifth or sixth time. Plus I knew some of the guys around here would want or need one sooner or later, and Les needed to move a few to pay for the initial costs of startup..Anyway - I still had one on the shelf. I went out and took a look and sure enough the circles that indicate where to drill for the core support are clearly present. I'll see if I can get a clear picture tomorrow with some indirect sunlight. {hard to get clear picture of an all shinny black surface with a flash}.Even in 71, in order to get that first couple of bolts threaded into the captive nuts - one had to push up with one's right hand with a lot of pressure - and start the bolt on its way in with your left hand. Just holding the Spook in place - it is about 0.5" of more below the core support. As it is flexed up and the three bolts are tightened down - it spreads out to the sides a bit as well.Not knowing much about the design of fiberglass structures, I don't know if this pre-stress is intentional or not. I do know that the original held up on my Z without showing any stress cracks etc - at least until I destroyed it on parking stops..Like I said - that was around 99 - so things might have changed since then..Definitely no circles on mine, the black gel-coat was beautifully smooth in the mounting area.The prestress bit is good to know, would have been even better to know when I first installed it, I'd have tried a bit harder to do it. The gap you describe sounds right to me, which is reassuring. At least I know mine is normal.I'll probably take a stab at using the core support holes again, with this new info. My fear is that I may have mounted mine a touch too far forward now. Link to comment https://www.classiczcars.com/forums/topic/30667-front-end-spook-options/?&page=8#findComment-282606 Share on other sites More sharing options...
May 4, 200915 yr Author comment_282642 Whether you did or not Arne, it looks just fantastic in your pictures! Link to comment https://www.classiczcars.com/forums/topic/30667-front-end-spook-options/?&page=8#findComment-282642 Share on other sites More sharing options...
May 4, 200915 yr comment_282649 I hope it's not too late, you may have other options than the Spook It's a JDM spoiler from RS-Start Link to comment https://www.classiczcars.com/forums/topic/30667-front-end-spook-options/?&page=8#findComment-282649 Share on other sites More sharing options...
May 4, 200915 yr Author comment_282653 Its too late...haha, but that looks really nice. Link to comment https://www.classiczcars.com/forums/topic/30667-front-end-spook-options/?&page=8#findComment-282653 Share on other sites More sharing options...
May 4, 200915 yr comment_282665 I hope it's not too late, you may have other options than the Spook It's a JDM spoiler from RS-Start Caen, where did you get it and what did you pay? Chris Link to comment https://www.classiczcars.com/forums/topic/30667-front-end-spook-options/?&page=8#findComment-282665 Share on other sites More sharing options...
May 4, 200915 yr comment_282676 I bought it from RS-START in Japan and had it shipped to me by a friend over there. The expensive part was the shipping. Can't remember how much it was 18 month ago Link to comment https://www.classiczcars.com/forums/topic/30667-front-end-spook-options/?&page=8#findComment-282676 Share on other sites More sharing options...
May 4, 200915 yr comment_282690 Hmmm. just had a look at there homepage and i cant find it, it might be that funny google translation that make it had for me.Please see if you can remember, i really like it.Chris Link to comment https://www.classiczcars.com/forums/topic/30667-front-end-spook-options/?&page=8#findComment-282690 Share on other sites More sharing options...
May 4, 200915 yr comment_282693 Is this it? http://translate.google.com/translate?hl=en&sl=ja&u=http://www.rsstart.com/&ei=VSH_Sc-ROpi8swOXqIXWAQ&sa=X&oi=translate&resnum=1&ct=result&prev=/search%3Fq%3DRS-Start%26hl%3Den%26rlz%3D1G1GGLQ_ENUS326%26sa%3DGIt guess it won't link directly to the correct page, but go to "Fairlady Z S30 Parts", then Fair Lady S30, S31FRP Parts"It looks like it is 26,250 yen.-Mike Edited May 4, 200915 yr by Mike B Link to comment https://www.classiczcars.com/forums/topic/30667-front-end-spook-options/?&page=8#findComment-282693 Share on other sites More sharing options...
