Afternoon everyone , I just finished building cowl drains for the Z . There was a thread from Enrique that I found and I followed his instructions and made what you see here . The pvc 90 degree was modified by cutting the one end shorter so it would fit into the rubber drain outlet easier and not bind while allowing the 90 to fit as close to the inner fender as possible . I found some woven tubing at 2$ per foot and and some gear clamps to go around the whole assembly and then secured the rubbe
