September 4, 201410 yr comment_454721 A few (two?) years ago I saw a rebuild kit for 240Z F.P. online; went back later and couldn't find it. Hope you find the parts. Looks like this thread was to find replacements for the OE Fuel pump but Denki is no longer made in Japan and the new ones are stamped metal which don't look right and are useless to me since I run a fuel pressure gauge from an AN hose tee'd from the outlet, impossible with stamped metal. My OE style Denki from Pep boys is fairly new but I want to rebuild my old Nikki that was on my '73 when I got it, for a spare.Also, been trying to get a OE style Carter (made in USA), but the new ones are stamped. I called the Carter factory many times, left messages and emailed them, trying to find the earlier type, but never received a reply. I called Rock Auto and they said they had the OE type Carter, and directed me to the photo of it on their site. Two days later the photo was removed (respect them for that).BTW my Denki is putting out 4.0 psi, and my float valves don't have a problem with it. Link to comment https://www.classiczcars.com/forums/topic/30699-240z-fuel-pumps-how-many-different-oems/?&page=4#findComment-454721 Share on other sites More sharing options...
September 4, 201410 yr comment_454722 Kerrigan, I have a bunch of old fuel pumps. I can scavenge any parts you need. Not sure how many Nikki or other. Let me know and I'll look. Just took a stock 10/70 engine apart that had one. Link to comment https://www.classiczcars.com/forums/topic/30699-240z-fuel-pumps-how-many-different-oems/?&page=4#findComment-454722 Share on other sites More sharing options...
September 4, 201410 yr comment_454738 BTW my Denki is putting out 4.0 psi, and my float valves don't have a problem with it.I put on an aftermarket Carter and it's putting out 6+ psi causing the carbs to load up, dump gas, and stall when idling. Putting a regulator in the line to limit it to 3.5 psi while I try to get my original 1501 pump rebuilt, or find a good condition Nikki replacement. Link to comment https://www.classiczcars.com/forums/topic/30699-240z-fuel-pumps-how-many-different-oems/?&page=4#findComment-454738 Share on other sites More sharing options...
September 4, 201410 yr comment_454739 What model is your Carter, mechanical or electrical? Link to comment https://www.classiczcars.com/forums/topic/30699-240z-fuel-pumps-how-many-different-oems/?&page=4#findComment-454739 Share on other sites More sharing options...
September 5, 201410 yr comment_454749 Stanley said: What model is your Carter, mechanical or electrical?Mechanical. Supposed to be for the 1971 FairladyZ. Carter M60107 on the box label. The sheet included shows diagrams of the original Nikki pump, version 1 and version 2, and says 1080 fuel pump assembly. It gauged putting out 6psi instead of the maximum 3.5psi the carbs will handle without flooding out at idle. Edited September 5, 201410 yr by Kerrigan Link to comment https://www.classiczcars.com/forums/topic/30699-240z-fuel-pumps-how-many-different-oems/?&page=4#findComment-454749 Share on other sites More sharing options...
August 18, 20168 yr comment_501283 1401 on Nov 69 HLS30-00249 Link to comment https://www.classiczcars.com/forums/topic/30699-240z-fuel-pumps-how-many-different-oems/?&page=4#findComment-501283 Share on other sites More sharing options...
February 19Feb 19 comment_674681 I know this is an old thread, but can anyone get me a side view of an Ampco pump? I am curious to see if it says Ampco on the side housing. Link to comment https://www.classiczcars.com/forums/topic/30699-240z-fuel-pumps-how-many-different-oems/?&page=4#findComment-674681 Share on other sites More sharing options...
February 20Feb 20 comment_674723 9 years! Nice Resurrection. My four Ampco bodies just say “Made in Japan” on the side Link to comment https://www.classiczcars.com/forums/topic/30699-240z-fuel-pumps-how-many-different-oems/?&page=4#findComment-674723 Share on other sites More sharing options...
February 20Feb 20 comment_674725 That is perfect, Thanks! Edited February 20Feb 20 by motorman7 Link to comment https://www.classiczcars.com/forums/topic/30699-240z-fuel-pumps-how-many-different-oems/?&page=4#findComment-674725 Share on other sites More sharing options...
February 20Feb 20 comment_674727 Now I need to find a Nikki top cap. Link to comment https://www.classiczcars.com/forums/topic/30699-240z-fuel-pumps-how-many-different-oems/?&page=4#findComment-674727 Share on other sites More sharing options...
