Email logins are now active ×
Need a part #
Weasel73240Z
I tried to order a new valve cover-to-air cleaner box hose from Courtesy, but I ended up with the hose that goes from the block (under the dizzy) to the PCV valve on the balance tube.
Does anyone have the part # for the valve cover-to-air cleaner hose that I need?
Also, the 1970 (or 1971) air cleaner box that I bought has 2 large connection in the back, apart from the fuel bowl overflow and the vacuum taps. I know that 1 of the connections if for the hose that I need, what is the other large one for? It faces downward, and I can't figure out what goes there.
Thanks as usual for the help.
If Puxatawney Phil was right, only 2-1/2 months and I'll be able to drive the Z again.:mad:
  • Who's Online   3 Members, 0 Anonymous, 309 Guests (See full list)
