Posted February 8, 200916 yr comment_273501 I have a new zx dizzy with a e12-80 module on a stock L28 motor with 4 bolt su carbs. are these msd 6a worth putting on or just leave the e 12-80 on thanks Link to comment https://www.classiczcars.com/forums/topic/30755-msd-ingition/ Share on other sites More sharing options...
February 8, 200916 yr comment_273549 I've heard nothing but good on the E12-80 module. I'm still running points, but if the change comes, it will be with the E12-80.Bonzi Lon Link to comment https://www.classiczcars.com/forums/topic/30755-msd-ingition/#findComment-273549 Share on other sites More sharing options...
February 8, 200916 yr comment_273561 You can use a MSD6a with an E12- 80 dizzy ,and you will have to also have to add a tach adapter. You may not notice any changes from an already proven setup. I,m running the MSD on my 74 260 to replace the factory transistorized ignition Link to comment https://www.classiczcars.com/forums/topic/30755-msd-ingition/#findComment-273561 Share on other sites More sharing options...
