Arne Posted February 10, 2009 Author Share #13 Posted February 10, 2009 A quick note - after hearing from another member here that his dealer wasn't able to get the check valves, I have confirmed that those valves are now shown as 'back-order' with no ETA. Not known whether any more will be offered in the future. Link to comment Share on other sites More sharing options...
Inf Posted April 24, 2009 Share #14 Posted April 24, 2009 Awesome, thanks for the info. Ordering my parts right now.I completely dismantled my fuel pump a few years back trying to troubleshoot something else, and my diaphragm was showing some signs of wear (It'll probably show some light surface cracking by the time I pull it out). Back then I just assumed the parts were nowhere to be found, because one of my manuals (Haynes maybe? FSM?) listed this as a "non-serviceable part." Link to comment Share on other sites More sharing options...
Kerrigan Posted April 10, 2014 Share #15 Posted April 10, 2014 I was able to obtain a rebuild kit out of Canada last week, so they are still around. 1 Link to comment Share on other sites More sharing options...
240Ziggy Posted April 11, 2014 Share #16 Posted April 11, 2014 hey Kerrigan, i'm in need to rebuild mine. Is it possible to pm me where you got them or post here? Thanks in advance.I was able to obtain a rebuild kit out of Canada last week, so they are still around. Link to comment Share on other sites More sharing options...
bvolken Posted February 20, 2015 Share #17 Posted February 20, 2015 Arne, EXCELLENT WRITE UP! Thanks. I hope you are OK, I took your excellent written instructions and added photos.Datsun 240z mechanical fuel pump rebuild.I gave you credit several places. For me, photos really help, especially down in the deep-dark spaces where you can't see!Regards. 1 Link to comment Share on other sites More sharing options...
NVZEE Posted February 22, 2015 Share #18 Posted February 22, 2015 (edited) You should add to the rebuild writeup that the info applies to the Nikki pump ONLY because of differences in the diaphragm design. Replacement diaphragms fit the Nikki and don't interchange with the Kyosandenki pump.http://www.classiczcars.com/topic/50224-fuel-pump-parts-interchange/?p=457702 Edited February 22, 2015 by NVZEE Link to comment Share on other sites More sharing options...
bvolken Posted February 23, 2015 Share #19 Posted February 23, 2015 So noted. Link to comment Share on other sites More sharing options...
TonyTomB Posted December 5, 2016 Share #20 Posted December 5, 2016 On 10/04/2014 at 5:01 PM, Kerrigan said: I was able to obtain a rebuild kit out of Canada last week, so they are still around. Hi Mr Kerrigan. My pump is the "Ampco G 22 " pump and I need the correct diaphram so I wonder if you could give me the site in Canada where you got your kit from.Thanks for you time. Kind regards.TonytomB Link to comment Share on other sites More sharing options...
siteunseen Posted December 5, 2016 Share #21 Posted December 5, 2016 This might get you a quicker response, that's an older post. @Kerrigan Link to comment Share on other sites More sharing options...
TonyTomB Posted December 7, 2016 Share #22 Posted December 7, 2016 Hi siteunseen. You may have seen my post to Mr Kerrigan if not I need a diaphram with rod to fit my ampco petrol pump for a 260z 1974. Could you supply me with any leads. Kind regards. Tonytonb On 05/12/2016 at 3:45 PM, TonyTomB said: Hi Mr Kerrigan. My pump is the "Ampco G 22 " pump and I need the correct diaphram so I wonder if you could give me the site in Canada where you got your kit from.Thanks for you time. Kind regards.TonytomB Link to comment Share on other sites More sharing options...
siteunseen Posted December 7, 2016 Share #23 Posted December 7, 2016 I was only notifying Mr Kerrigan through the Forum. It's been a couple of years since he posted that. Best of luck. Cliff Link to comment Share on other sites More sharing options...
Mike Posted December 8, 2016 Share #24 Posted December 8, 2016 Let me know if you guys need to update the article in the knowledge base. Link to comment Share on other sites More sharing options...
