lm71z Posted February 9, 2009 Share #1 Posted February 9, 2009 I recently set the idle to exactly 1,000rpm on my 240z. When I'm driving the car the idle almost never comes back down to 1,000rpm when I come to a stop. I have to tap the gas pedal and let my foot off of it in order for the idle to come back down to 1,000rpm. If I don't tap the gas pedal the idle returns to about 1100rpm. Does anyone know what could be causing this problem? Link to comment Share on other sites More sharing options...
Bruce Palmer Posted February 9, 2009 Share #2 Posted February 9, 2009 I've seen similar where because of worn throttle shafts, over-size return springs have been installed to get things to idle down. What, in fact, happens is the too heavy return springs will pull the shafts into a bind thus requireing the "tap'............. Link to comment Share on other sites More sharing options...
lm71z Posted February 9, 2009 Author Share #3 Posted February 9, 2009 So what parts do I need to buy and where can I get them at? Link to comment Share on other sites More sharing options...
Bonzi Lon Posted February 9, 2009 Share #4 Posted February 9, 2009 Mine was acting up after sitting for 26 years. I removed, cleaned and greased every ball and socket joint from the foot feed to the carb connecting shaft. So much smoother now.Bonzi Lon Link to comment Share on other sites More sharing options...
sblake01 Posted February 9, 2009 Share #5 Posted February 9, 2009 So what parts do I need to buy and where can I get them at?I believe that worn throttle shafts require machine work. Might be time to contact Bruce about his product if that's the case. Link to comment Share on other sites More sharing options...
