Posted February 9, 200916 yr comment_273651 Hi guys! NO, this ISNT another question about how to remove bushings from the FRONT suspension arm (Transverse control arm). The problem is that i tried removing the big bolt that connects the suspension arm to the chassis, but then the INNER sleeve got stuck on the bolt and the rubber just got all ripped up (so i just torched the rubber off), so the INNER sleeve is now acting as a stopper of sorts preventing the bolt from going out even after giving the nut end(nut removed of course) a few whacks with a hammer! Earlier on i put a vise grip on the INNER sleeve with just enough grip (too much and i might deform the sleeve and make it even tighter) so i could rotate the bolt with a socket without the sleeve moving, and it worked. So i released the vise grip and hammered away at the nut end hoping the sleeve loosened up on the bolt and still the bolt refused to go out! I thought about cutting off the head and pushing it out from the susp arm but the hacksaw wont fit there. I would rather save the bolt if possible since i`m not sure if i can get a similiar bolt over here. In fact i`m not even sure if this is the right bolt, are there GRADE MARKINGS on the head of an original bolt for the 240z? ANY and ALL advice appreciated! THANKS! Edited February 9, 200916 yr by PATZ added word Link to comment https://www.classiczcars.com/forums/topic/30773-front-suspension-arm-bolt-stuck-to-bushing-sleeve/ Share on other sites More sharing options...
February 9, 200916 yr comment_273655 Post some pics if you can. When I took my front suspension apart, everything came out real easy after 35 years.If all else fails, usually enough heat will get anything loose/disconnected. Link to comment https://www.classiczcars.com/forums/topic/30773-front-suspension-arm-bolt-stuck-to-bushing-sleeve/#findComment-273655 Share on other sites More sharing options...
February 10, 200916 yr Author comment_273725 Weasel73240Z- My camera conked out, i`ll just try some heat then. THANKS! Link to comment https://www.classiczcars.com/forums/topic/30773-front-suspension-arm-bolt-stuck-to-bushing-sleeve/#findComment-273725 Share on other sites More sharing options...
February 10, 200916 yr comment_273734 If you're using a bernz-o-matic torch, make sure you use MAPP gas (in the US it comes in a yellow tank). It burns much hotter than propane, and heats things up quickly. Link to comment https://www.classiczcars.com/forums/topic/30773-front-suspension-arm-bolt-stuck-to-bushing-sleeve/#findComment-273734 Share on other sites More sharing options...
February 10, 200916 yr comment_273764 lots of lube for a couple days then heat and crap loads of it. Early 90's hondas are notorious for this in the rear suspension, the bushing seizes to the bolt and it takes forever to get it apart. Edited February 10, 200916 yr by gotswap Link to comment https://www.classiczcars.com/forums/topic/30773-front-suspension-arm-bolt-stuck-to-bushing-sleeve/#findComment-273764 Share on other sites More sharing options...
February 11, 200916 yr Author comment_273805 weasel73240Z- we in fact have an acetylene torchgotswap-THANKS for the advice! Link to comment https://www.classiczcars.com/forums/topic/30773-front-suspension-arm-bolt-stuck-to-bushing-sleeve/#findComment-273805 Share on other sites More sharing options...
February 11, 200916 yr comment_273825 PATZ said: weasel73240Z- we in fact have an acetylene torchYou've got plenty of heat then...good luck. :rambo: Link to comment https://www.classiczcars.com/forums/topic/30773-front-suspension-arm-bolt-stuck-to-bushing-sleeve/#findComment-273825 Share on other sites More sharing options...
February 13, 200916 yr Author comment_274082 Hi guys! Just thought i`d let you know that i finally got the suspension arm mounting bolt off. Yes the inner sleeve was stuck to the bolt, but not as much as i thought. What was really causing my problem was that each time i whacked one end of the bolt(to push it out), the chassis mounting point area just flexed (vibrated?) and kinda pushed the bolt back in! So someone suggested to get a stout piece of water pipe and push it against the chassis mounting point area (the part facing the front of the car) to hopefully reduce the flexing/vibration. I then whacked the other end of the bolt again and voila! the bolt moved out FINALLY! Man that felt good!! Link to comment https://www.classiczcars.com/forums/topic/30773-front-suspension-arm-bolt-stuck-to-bushing-sleeve/#findComment-274082 Share on other sites More sharing options...
February 13, 200916 yr comment_274097 Success!!!!!! Link to comment https://www.classiczcars.com/forums/topic/30773-front-suspension-arm-bolt-stuck-to-bushing-sleeve/#findComment-274097 Share on other sites More sharing options...
