The first owner had a sail board that he hitched to the rear :squareeye
Odd, I don't recall that set of parameters on the aerodynamic tests conducted by the hybridz guys...
Must have been an oversight.
I wonder what the downforce generated might be at full or half mast...
https://www.classiczcars.com/forums/topic/30783-idaho/#findComment-275316
I think it was more as a source of green energy (windpower) than handling LOL
-Mike
https://www.classiczcars.com/forums/topic/30783-idaho/#findComment-275317
The mods (except rear discs) were done very early in the little zed's life. A mound of paperwork was provided by the po. Driver's seat is courtesy of Recaro and if your not possitioned correctly before dropping in.. "WTF !!" is the common response. The seat looks plush but hiding under that slick black fabric showing off the huge bolstering seams to be 1/8 inch plate steel. Take some of that to the back side of your thigh, or your crack. OUCH !! But, once you get settled in it's pretty cozy.
https://www.classiczcars.com/forums/topic/30783-idaho/#findComment-275640
