Email logins are now active ×
1973 Datsun lug sizeing question.
MaximaCatt
  • 3 weeks later...
Hi!
Datsun, Nissan, Toyota, Honda, Mitsubishi has 4,5" /4 and that is the same as 114,3mm /4 boltpattern. Volvo V40 and S40 has 114,3mm /4 as well.
But check the center hole diameter, it's not the same...
for example an old Toyota wheel has a smaller diameter then a 240z.
Henrik
Whoa!
1.25mm for a diameter would be .0049" and NOT what you are looking for. The 1.25 refers to the PITCH of the thread, or if I recall right that it will move out 1.25mm for every full turn of the Nut. (Please correct me if I'm wrong!)
The Lug Nut Dimensions are as follows:
Diameter: 12mm (or 1.2cm or .4724")
Thread Pitch: 1.25RH
Not sure on the measurement for center to center, (can't find in my books yet) or diagonal.
Hope this helps.
