smg1404 Posted September 22, 2002 Share #1 Posted September 22, 2002 Todays effort now mostly complete. I still need to rework the lines a little. Link to comment Share on other sites More sharing options...
Ed Posted September 22, 2002 Share #2 Posted September 22, 2002 Let us know if there is a big differance in braking performance. I wouldn't mind doing the upgrade myself if indeed it would be an upgrade. I thought the stock calipers did a pretty good job. Link to comment Share on other sites More sharing options...
smg1404 Posted September 22, 2002 Author Share #3 Posted September 22, 2002 I still have some air in the system,, or something else going on. But I can tell already that the increase in stopping power is fantastic.. Before I had brakes... Nothing to brag about, but they stopped the car (sort of)... Now even though I have a bit to much pedal travel, I feel like I have the ability to chock the brakes easily any time I want... I have only driven a few miles so far on this new setup, but I thinl it was a good thing to do... I feel safer.I probably spent too much, I bought a set of used calipers for $80.00, and after looking them over, decided that I wanted to trade them in for rebuilds... So I have about $240.00 in the upgrade, but I have all new or rebuilt hardware.. I used the old set for cores. With brakes better safe than sorry..The calipers I used are from an '88 4Runner 6 cylinder... They had bigger pistons than the 4 cylinder set.. I had to space the calipers inward 1/8th of an inch. I bought hardened washers for this. I also used 1/8th inch wheel spacers to give a little more clearance between the caliper and my wheels..The 1/8th inch spacing inward put the caliper dead center with the disk. I was concerned at first, because the space between the rotor and the pads seemed like too much. But when I checked out how deep the pistons went into the caliper , I saw that there was plenty travel to handle this gap... After I pumped them in the brakes seem to work very well.. Link to comment Share on other sites More sharing options...
laffeaux Posted September 22, 2002 Share #4 Posted September 22, 2002 Did you upgrade the rear to disk too? I thought about upgrading the fronts, but thought that I'd have to upgrade the rear at the same time and didn't have the cash. Link to comment Share on other sites More sharing options...
smg1404 Posted October 1, 2002 Author Share #5 Posted October 1, 2002 No... I would like to, but I probably need to put money into other parts of the car. I will probably add a brake proportioning valve.The brakes are working much better now, I have plenty of power to put to the fronts.. They lock first now, so I want to add a valve to try and balance the brakes. Link to comment Share on other sites More sharing options...
