Posted February 17, 200916 yr comment_274627 I have a 72 240. My license plate light cover (black) is held on to the white plastic base that contains the bulbs by way of three screws. Im looking to replace it and Im being told that the 1 screw type is the same. I believe the single screw type is from later cars such as the 260 or 280. They look different, I dont know if they would fit back and forth. Perhaps some of you could help me out on this. Link to comment https://www.classiczcars.com/forums/topic/30865-license-plate-light-debate/ Share on other sites More sharing options...
February 18, 200916 yr Author comment_274677 One of you has to know this! The three screws can be seen standing behind your car! The single screw type shows only a smooth finish. Anyone?? Im in need of the three screw type as I believe it to be original, info anyone? Link to comment https://www.classiczcars.com/forums/topic/30865-license-plate-light-debate/#findComment-274677 Share on other sites More sharing options...
February 18, 200916 yr comment_274679 can't figure that out, any pix for that? Link to comment https://www.classiczcars.com/forums/topic/30865-license-plate-light-debate/#findComment-274679 Share on other sites More sharing options...
February 18, 200916 yr comment_274682 I remember my 71' having three screws holding it on. I don't know about the later cars. Link to comment https://www.classiczcars.com/forums/topic/30865-license-plate-light-debate/#findComment-274682 Share on other sites More sharing options...
February 18, 200916 yr comment_274698 This is the configuration on my 05/72 HLS30.... Link to comment https://www.classiczcars.com/forums/topic/30865-license-plate-light-debate/#findComment-274698 Share on other sites More sharing options...
February 18, 200916 yr Author comment_274711 This is the configuration on my 05/72 HLS30....[ATTACH]28271[/ATTACH][ATTACH]28272[/ATTACH] Yes. That is how my 72 looks also. Every picture I look at for correct 240Z's has three screws holding the light cover on.. ...the only pics I can find showing no screws are of 260 and 280 Z's. anyone else know about this/ ? Link to comment https://www.classiczcars.com/forums/topic/30865-license-plate-light-debate/#findComment-274711 Share on other sites More sharing options...
February 18, 200916 yr comment_274717 Now I am not positive but believe that they are the same 1970 thru 1978. The three screw type that is. I am however sure that you can get a new one OEM from your Datsun dealer. Why not put the original back on? Just my two cents worth. Link to comment https://www.classiczcars.com/forums/topic/30865-license-plate-light-debate/#findComment-274717 Share on other sites More sharing options...
February 18, 200916 yr comment_274736 The license plate light on my 74/260Z doesn't look anything like that. There are no screws to be seen.Rick.:devious::devious: Link to comment https://www.classiczcars.com/forums/topic/30865-license-plate-light-debate/#findComment-274736 Share on other sites More sharing options...
February 18, 200916 yr comment_274741 My 7/73 is the 3 screw type.Bonzi Lon Link to comment https://www.classiczcars.com/forums/topic/30865-license-plate-light-debate/#findComment-274741 Share on other sites More sharing options...
February 18, 200916 yr comment_274765 My 78 license plate lamp is held on with two screws that are on the ledge, on either side of the hatch's latch. The bulbs are accesible after you remove the lamp. Sorry, no picture. Edited February 18, 200916 yr by TomoHawk Link to comment https://www.classiczcars.com/forums/topic/30865-license-plate-light-debate/#findComment-274765 Share on other sites More sharing options...
