lm71z Posted February 19, 2009 Share #1 Posted February 19, 2009 What do you guys think is the best aluminum polish for removing oxidation and scratches? The valve cover on my 240z has nicks all through it; hopefully they will polish out. I'm guessing I'll need a pretty abrasive polish to get the job done right. Link to comment Share on other sites More sharing options...
DeesZ Posted February 19, 2009 Share #2 Posted February 19, 2009 Do you have any pictures of the "nicks" and "scratches"? You may be facing a job of sanding prior to polishing. Many of us have refurbished these things so I'm sure if we saw what you were talking about you'd get some good advice. (For cam covers, check out the photo gallery - lots of pictures by many members.) Link to comment Share on other sites More sharing options...
beandip Posted February 19, 2009 Share #3 Posted February 19, 2009 Polish will only shine the metal that is smooth and blemish free. If you have scratches or nicks you will need to lower the surrounding level of metal down to the bottom level of the scratch or nick. Now having said that , polish will remove some metal , not much but a little. Light surface blemishes can be removed with polish with a lot of rubbing. So if you want to remove a scratch , buy some 1500 grit wet/dry sand paper and use water or kerosene to wet the paper and remove the metal and blend in the scratch. Then I use a buffing wheel on either a die grinder or on my drill press and some polishing compound to buff out the light scratches left by the 1500 paper. Also try some 0000 ,4 ott, steel wool, with any liquid aluminum polish. I know of no short cuts , it just takes time. Gary Link to comment Share on other sites More sharing options...
Zs-ondabrain Posted February 19, 2009 Share #4 Posted February 19, 2009 hollelujaw brotha. Elbow grease, sweat, tears and a whole lotta sanding and polish. Look at the carb forum, you'll see the domes I just did. They are small and still took about an hour and a half each. Those, compared to a whole valve cover = time and patience. Have fun, the end result is well worth the effort. Dave. Link to comment Share on other sites More sharing options...
DeesZ Posted February 19, 2009 Share #5 Posted February 19, 2009 Like Dave said.... "Elbow grease, sweat, tears and a whole lotta sanding and polish......" But the results are likely to please you. Link to comment Share on other sites More sharing options...
240znz Posted February 19, 2009 Share #6 Posted February 19, 2009 I would recommend Autosol as a good polish for all metals. Link to comment Share on other sites More sharing options...
padam07 Posted February 19, 2009 Share #7 Posted February 19, 2009 I like to use Nevr-Dull for any king of metal polish. Link to comment Share on other sites More sharing options...
ta240 Posted February 20, 2009 Share #8 Posted February 20, 2009 (edited) on my wheels I did light wet sanding with 1500 grit then 2000 grit paper. Then switched to eagle1 polish on a Mothers powerball mini until it shreaded. Losing hope at that point I switched to Mothers Billet polish: http://www.mothers.com/02_products/05106.html and a couple drill mounted buffers from the local Harbor Freight: http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=34743 http://www.harborfreight.com/cpi/ctaf/displayitem.taf?itemnumber=65001 on the other 2 wheels I've done so far I did more sanding, even starting with 600 paper, since as they said above the polish won't take out much of an imperfection. With the finer grit papers I find it easy for it to gunk up with stuff and actually leave some pretty bad scratches if I don't keep the water flowing. that is when the finish came alive Edited February 20, 2009 by ta240 Link to comment Share on other sites More sharing options...
Carl Beck Posted February 20, 2009 Share #9 Posted February 20, 2009 Never-Dull.... as used on Air Force 1. No question it's one of the best products for metal polishing by hand. I've been using it since the mid-60's.I don't know what "Eagle One" adds to the price - but you can buy the original at any ACE Hardware store.FWIW,Carl B. Link to comment Share on other sites More sharing options...
ta240 Posted February 20, 2009 Share #10 Posted February 20, 2009 Never-Dull.... great, with my addiction to all things polish, I have to get some now. Link to comment Share on other sites More sharing options...
Bonzi Lon Posted February 20, 2009 Share #11 Posted February 20, 2009 I asked an old timer, old school, mechanic, gear-head this question yesterday and his reply was quick, "Nevr-Dull".Bonzi Lon Link to comment Share on other sites More sharing options...
padam07 Posted February 20, 2009 Share #12 Posted February 20, 2009 Never-Dull.... as used on Air Force 1. No question it's one of the best products for metal polishing by hand. I've been using it since the mid-60's.I don't know what "Eagle One" adds to the price - but you can buy the original at any ACE Hardware store. FWIW, Carl B. Yeah I am not sure about the egle one thing but I do know that you can get it just about anywhere. Walmart, Kmart, etc. Here is a pick of the original container. Link to comment Share on other sites More sharing options...
