Email logins are now active ×
Is it the head gasket or a fuel problem???
Tim 76' 280Z
Ok back in november I thougt I might of had a blown head gasket and I still might but... I was thinking maybe the problem is in the fuel. The car is so hard to start and when it does run it hardly stays running. The car does push out a little white smoke but not tons. I looked at the oil and it looks fine. Have not drained the oil tho. Looked in the raditor, looks like there might be some small beads of oil in the coolant but not totally positive. This all started when the car would just die while driving it. So what you all think?!? The car is a 76.
I went outside where I have had the z covered all winter and tried to see if she would start. To my surprise she did! But still ran like crap! I uncovered her really fast then drove her in the garage then shut her off. There was gas leaking from the back at the fuel pump. Some old fuel lines needed replacing. Fixed them then started the car. The lines werent leaking. Problem sloved there. When I looked up there was fuel squirting out around the first fuel injector. All the lines for the injectors are new.
Is this common when you have a blown head gasket or do I have some find of fuel problem?
