Did 240Z's have any type of inner fender for the front ?
A front "inner fender" is usually that part of the car that is toward the inside of the car, relative to the back side of the wheel/tire - and which protects and/or forms the engine bay. In that case, Yes there are innerfenders on the 240Z. They are listed as ASSY-HOOD LEDGE LH and RH in the parts catalogs.
The micro fiche doesn't help.
It seems a bit strange that rocks could hit the under side of the top
of my front fenders.
I don't believe that rocks can hit the under side of the top of your front fenders. Rocks would hit what we usually call the front fender horns - but which the parts catalogs list as ASSY-REINF HOOD LEDGE RH & LH. If you take your front fenders off - you will see that these parts are under the tops of the front fenders..
FWIW,
Carl B.
