Email logins are now active ×
Great, the brakes now!
Caen Fred
I will sort it all one dayLOL
I have a quickie about the check valve.
I have 280ZX front brakes with a 280ZX booster and master cyl on my 240Z legs...
If I use the check valve the way it supposed to, the brakes are very firm and not too powerful. If I reverse it, the brakes are quite strong but the pedal travel is enormous :ermm:
Any thoughts?
I don't know what the Haynes manual says because I don't use it. The end of the check valve that you can pull vacuum through goes towards the engine, the end you can't pull vacuum through goes towards the Master Vac. If you can pull vacuum through both ends it needs to be replaced.
  • Who's Online   2 Members, 0 Anonymous, 196 Guests (See full list)
