Posted February 28, 200916 yr comment_275684 I am in need of a front grill for my 1970 240, will the grill's off of a 72 or 73 fit? I did a search but nothing came up. I have no idea if they are any different on the early cars. Is there an aftermarket one?Thanks for any info, or if someone has a nice example and wants to sell it let me know.Thanks,Randy Link to comment https://www.classiczcars.com/forums/topic/30974-front-grill-info-needed/ Share on other sites More sharing options...
February 28, 200916 yr comment_275685 The '70-72 are all the same. The '73 is a bit different in mounting points, I believe. Link to comment https://www.classiczcars.com/forums/topic/30974-front-grill-info-needed/#findComment-275685 Share on other sites More sharing options...
February 28, 200916 yr comment_275686 Arne said: The '70-72 are all the same. The '73 is a bit different in mounting points, I believe.I think Arne is correct, just the 73 is different.-Mike Link to comment https://www.classiczcars.com/forums/topic/30974-front-grill-info-needed/#findComment-275686 Share on other sites More sharing options...
February 28, 200916 yr comment_275692 I believe I have one of each. Let me know which one will fit. The pic on the left is from a 71-72. It is identical to the grille in my 71. (mounting tabs face inward) On the right is the 73. (mounting tabs face outward) Link to comment https://www.classiczcars.com/forums/topic/30974-front-grill-info-needed/#findComment-275692 Share on other sites More sharing options...
February 28, 200916 yr comment_275722 Sorry for jacking this thread, what color did the grill come in, mine is painted in body color, should it be black or grey as the tail light sorround.Chris Link to comment https://www.classiczcars.com/forums/topic/30974-front-grill-info-needed/#findComment-275722 Share on other sites More sharing options...
February 28, 200916 yr comment_275729 2 fast 2 Z said: Sorry for jacking this thread, what color did the grill come in, mine is painted in body color, should it be black or grey as the tail light sorround.ChrisIt should be grey, like the rear taillight surround. The paint that Les at classicdatsun sells is a good match.-Mike Link to comment https://www.classiczcars.com/forums/topic/30974-front-grill-info-needed/#findComment-275729 Share on other sites More sharing options...
February 28, 200916 yr Author comment_275733 George,PM sent. Link to comment https://www.classiczcars.com/forums/topic/30974-front-grill-info-needed/#findComment-275733 Share on other sites More sharing options...
