75 280. In process of cleaning up engine compartment, cleaned and re-wrapped all the wires running over the engine, etc. Mistakenly, I cranked the car up without the coil wire plugged into the coil. Shot sparks out pretty good! Now it runs kinda rought. I replaced cap, rotor, coil, plug wires (was planning to do that anyways), still have the miss. Pulled each plug wire separately to isolate, appears to be #2 cyl. What would make just that one not fire? Did I fry something?
https://www.classiczcars.com/forums/topic/30987-engine-miss/
Im not giving the experts much to go on here, I know. I would consider myself an average enthusiast, so I know it either spark or fuel. Injector wiring seems OK. Mainly wondering if you can fry any of the EI stuff by cranking w/o the coil wire in (the one to the dist).
Also, why do they still have a ballast resitor on an EI car? Can I by pass this for a hotter spark. I have searched past posts and I guess you can but then why did they come from Datsun with the resistor?
I doubt that you could have done anything to the ignition system that would only affect one cylinder.
I also thought that the ballast resistor existed to protect the breaker points, so I do not know why a car with electronic ignition would have a resistor, unless it originally came with points and someone converted it after the fact. Actually, I don't know when Nissan went to electronic ignition.
Unless proven otherwise, I would proceed with the assumption that your problems with the #2 cylinder are not related to cranking the engine with the coil wire disconnected.
Now, I have seen people damage a cylinder head by plugging one of their spark plug wires into the coil and cranking the engine for an extended period of time trying to start the car... That isn't what you describe, so start looking at the cylinder with the problem.
So can I remove it without damaging anything? Ignition is all stock except for Crane wires and Blaster 2 coil.
Not sure if I would do that. Nissan must have had a reason for setting it up that way. The ignition modules are different for the 75-77 models vs. the 78 and the ballast resistor is between the coil and the module. I wouldn't take the chance of possibly damaging something by removing it.
