Posted September 23, 200222 yr comment_16131 would wheels in this size fit a 240Z? i plan on using the factory japanese flares on my 240Z...bolt pattern is right but i'm jus wondering about clearance and if the flares would cover...16x7.5 offset +616x8 offset +13 Link to comment https://www.classiczcars.com/forums/topic/3099-would-this-fit-a-240z/ Share on other sites More sharing options...
September 23, 200222 yr comment_16138 More than likely if the bolt pattern matches, ytou need to get a wheel adapter because the Z uses a zero offset wheel. Hope this helps. Link to comment https://www.classiczcars.com/forums/topic/3099-would-this-fit-a-240z/#findComment-16138 Share on other sites More sharing options...
September 23, 200222 yr comment_16150 16x7.5 offset +616x8 offset +13 Plus 6 what? plus 13 what?you gonna cut out the metal under the flares? Link to comment https://www.classiczcars.com/forums/topic/3099-would-this-fit-a-240z/#findComment-16150 Share on other sites More sharing options...
September 29, 200222 yr Author comment_16401 mr.camo,i meant plus 6" and plus 13" for the offset....hahahaah...i thought offset was usually measured in mm? Link to comment https://www.classiczcars.com/forums/topic/3099-would-this-fit-a-240z/#findComment-16401 Share on other sites More sharing options...
