Posted March 4, 200916 yr comment_276204 or i will give you the low down and ne input would be good i got a 72 240z the head gaskit was blone so i changed it and i put 71 su carbs know it runs good but smokes more or less depending on how i set the carbs i can set the carbs to not smoke but the engine will hesitate on exceleration bad oh yea 1,2,and3 spark plugs look good but 4,5,and6 have a light gray coat on them Link to comment https://www.classiczcars.com/forums/topic/31026-72-240-carbs/ Share on other sites More sharing options...
March 4, 200916 yr comment_276205 Assuming that the throttle shaft bushings are not worn out (a big assumption after all these years), here is a quick primer on how to adjust them.http://classiczcars.com/forums/showthread.php?t=9477 Link to comment https://www.classiczcars.com/forums/topic/31026-72-240-carbs/#findComment-276205 Share on other sites More sharing options...
March 4, 200916 yr Author comment_276207 thank you i have not used it yet but i dont see how i can mess it up with infermtion like that Link to comment https://www.classiczcars.com/forums/topic/31026-72-240-carbs/#findComment-276207 Share on other sites More sharing options...
March 4, 200916 yr Author comment_276208 thank you i have not used it yet but i don't see how i can mess it up with information like that Link to comment https://www.classiczcars.com/forums/topic/31026-72-240-carbs/#findComment-276208 Share on other sites More sharing options...
March 5, 200916 yr comment_276353 See your other post called "Problem" for more carb info. Link to comment https://www.classiczcars.com/forums/topic/31026-72-240-carbs/#findComment-276353 Share on other sites More sharing options...
March 5, 200916 yr Author comment_276357 Ok I did the test that arne sent me and the car runs great know but a minor hesitationBut I ordered a uni-sun and wen it gits here thay should be perfect Link to comment https://www.classiczcars.com/forums/topic/31026-72-240-carbs/#findComment-276357 Share on other sites More sharing options...
