At the end of the summer last year, I came to the conclusion that the syncros in my 4-speed trans were going bad. And I've decided to go with the 240sx trans.
I am aware that my bell housing needs some modification to fit the sx trans. I've already talked to a local machine shop. The driveshaft will probably have to be shortened. I've done a great deal of research and I'm pretty confident in my ability to make this work. But I was wondering, if there is anyone else out there that's done it, do you have any advice?
Hey, Darb, welcome back.
I don't know much about the details of going to the 240SX transmission, but I do have a question. Considering how simple and straightforward swapping a 280ZX 5 speed into your car is, what prompted your decision to do the much more difficult job?
The 240SX (or KA) transmission is superior. Having built many early transmissions and finally completing this conversion for myself I can say it's worth the minor trouble. Head over to www.hybridz.org and search for the 240SX or KA swap. There's plenty of documented information.
The complete article by Steve Heimsouth, related to the 240ZX Transmission swap - is hosted on the Z Car Home Page
http:ZHome.com in "the Z Car Technical Library" section.
The direct URL is:
http://ZHome.com/ZCMnL/tech/240SX5spd/transmission.htm
FWIW,
Carl B.
Edited by Carl Beck
Most Likely - - -
240SX transmission
- stronger, new and improved design
- gearing 1st through 4th closer to original
- easier to find low mileage examples today
- usually not too expensive
- rebuild parts still easily available
FWIW,
Carl B.
  Carl Beck said:
Most Likely - - -
240SX transmission
OK, I can see where these are all desirable things. However:
  • stronger, new and improved design - perhaps, but I doubt that any stock or mildly enhanced 240/280Z truly needs a stronger tranny for street use.
  • gearing 1st through 4th closer to original - a generally good thing, but again, I doubt the differences are all that significant for a street-driven Z.
  • easier to find low mileage examples today - probably true in much of the country. Not so much here in the West, where there's still plenty of Z/ZX transmissions available.
  • usually not too expensive - neither are the ZX trannies.
  • rebuild parts still easily available - I had no trouble getting rebuild parts for my Type A last year, and Type B 5 speeds should be even easier to get parts for.
Not trying to say this is a bad idea, I don't see much downside to it, other than all the extra work and cost to pull it off.
  Arne said:
stronger, new and improved design - perhaps, but I doubt that any stock or mildly enhanced 240/280Z truly needs a stronger tranny for street use....
When I bought my 240Z (in 2002) it had been sitting in a warehouse for more than a decade. The transmission that came in it was from a 280Z, and the syncros for 2nd gear were shot. The title (from 1983) listed the purchase mileage at 134k miles and the odometer read just a little over 40k. From that I assume the car had about 140k miles, was on at least its second transmission, and that one was pretty much shot.
A stronger transmission would be a good thing...
The 240SX runs a 4:10 rear end stock. If you don't have at least a 3:90 you might be a little disappointed with the gearing. Or not. I have one (240SX) and I'm not a big fan of the rpm drop in the 1-2 shift. First is just a little too low so the jump to second is a little too much IMHO. But the rest have nice spacing. With a 3:90 the 1-2 shift would be little worse, but at least first gear wouldn't run out so quick and you'd be turning a few less rpm at highway speeds.
Steve
Well, basically I needed a transmission solution. And after looking at different options, I decided not to go with the 280zx trans because I am certain to have the same problem with syncros going out. All of the zx transmissions I was able to find were expensive and had higher miles than my own broken transmission.
I am really excited about this swap. In fact all I am waiting for is the bell housing and driveshaft to come back from the machine shop! I will keep you posted. Thanks for all the info.
