Posted March 7, 200916 yr comment_276615 OK, before everyone get's uptight thinking I am going with this let me say NO I am not putting this in my 72 Z. I had always thought I would like a Jag IRS for my 73 240Z when I did the V-8 swap. So awhile back I picked up a 85 Jag XJ6 on E-bay for near nothing. Well I just got around to pulling it today. OMG I LOVE IT!!!!! It's just way to cool for me ta hide under a car. So I am going to use it in an open wheel 37 chevy pickup that I have been saving parts up for. Anyway, I did want to show it off alittle and let you all see just what its about. I do think it would be a real easy swap into a Z if you wanted. Edited March 7, 200916 yr by carguyinok Link to comment https://www.classiczcars.com/forums/topic/31080-check-out-my-jag-irs/ Share on other sites More sharing options...
March 7, 200916 yr comment_276654 I love inboard brakes. Have you seen Bryan Feldmans Jag rear end in a 510? http://www.bryanf.com/510/rsusp.htm Link to comment https://www.classiczcars.com/forums/topic/31080-check-out-my-jag-irs/#findComment-276654 Share on other sites More sharing options...
March 7, 200916 yr comment_276658 Pretty much the same rear as in my '66 E-Type. Link to comment https://www.classiczcars.com/forums/topic/31080-check-out-my-jag-irs/#findComment-276658 Share on other sites More sharing options...
March 7, 200916 yr comment_276669 Inboard brakes... glad I don't have to mess with those! Link to comment https://www.classiczcars.com/forums/topic/31080-check-out-my-jag-irs/#findComment-276669 Share on other sites More sharing options...
March 8, 200916 yr comment_276707 I'm in love with that design! I know how impractical it is compared to other more conventional setups, but: Inboard discs! 4 struts! Torsion bars!It's awesome! Link to comment https://www.classiczcars.com/forums/topic/31080-check-out-my-jag-irs/#findComment-276707 Share on other sites More sharing options...
March 8, 200916 yr Author comment_276730 Thank you for that link. No I hadnt seen that one before. I was thinking about just doing a wide body kit vs. cutting the rear end down. But now it's no longer for the 240Z so that dosnt matter any more. Now the plan is just pulling it apart and powder coating everything. Then new bushings, ujoints, bearings and brakes. After that it's going into my 37 chevy pickup street rod. Unless I come up with a T bucket body that is. I dont mind the inboard brake set-up. For that matter its one of the things I love about it. If you look close you will see that the brake cal. have a piston on bolth sides of the rotor. Sure it looks like a pain in the butt. But I plan on making it so I can drop the whole rearend out rather fast. Just for ease of service. With only 6 mounting points why not. Edited March 8, 200916 yr by carguyinok Link to comment https://www.classiczcars.com/forums/topic/31080-check-out-my-jag-irs/#findComment-276730 Share on other sites More sharing options...
