Posted March 9, 200916 yr comment_276814 Hey guys I have a 240z that I have lightly modded and won't do a swap with. However I do have a rolling chassis 240z as well. I came across a 280zxt with 220,000 miles on it that ran a month ago, turns over currently, but does not start. It rows through the gears fine and the drive train looks straight. I want the drive train parts of course to put into my rolling chassis. The exterior and interior are aged of course, all those miles. I have no idea what this 280zxt should be worth. Any ideas? Link to comment https://www.classiczcars.com/forums/topic/31099-is-a-used-280zxt-worth-450/ Share on other sites More sharing options...
March 9, 200916 yr comment_276820 If you saw it run and nothing has been removed, the complete drivetrain/ECM/HARNESS is worth $450. IF YOU DIDN'T SEE IT RUN, I WOULD QUESTION WHY IT WOULD GO DOWN IN ONLY A MONTH-and want to see it running-even if it us started and run on a simple propane cylinder with the hose going into the air filter box(it can be done simply) !Will Link to comment https://www.classiczcars.com/forums/topic/31099-is-a-used-280zxt-worth-450/#findComment-276820 Share on other sites More sharing options...
March 9, 200916 yr comment_276831 agreed. otherwise, do a compression check to make sure at minimum that the basics of the block are in order. at $450 you can part out the rest and free drive train. Link to comment https://www.classiczcars.com/forums/topic/31099-is-a-used-280zxt-worth-450/#findComment-276831 Share on other sites More sharing options...
March 10, 200916 yr comment_276959 If you saw it run and nothing has been removed, the complete drivetrain/ECM/HARNESS is worth $450. IF YOU DIDN'T SEE IT RUN, I WOULD QUESTION WHY IT WOULD GO DOWN IN ONLY A MONTH-and want to see it running-even if it us started and run on a simple propane cylinder with the hose going into the air filter box(it can be done simply) !WillThat sounds like a dangerous experiment frought with danger for someone who doesn't know exactly what they're doing. :paranoid: Link to comment https://www.classiczcars.com/forums/topic/31099-is-a-used-280zxt-worth-450/#findComment-276959 Share on other sites More sharing options...
March 11, 200916 yr comment_277025 Hadn't though of that...When I get back from Amelia, I'll write a technical article on how to do it safely-in the mean time, a squirt from a can of starter fluid could be used as wellfollowing all of the directions on the can to the letter.Will Link to comment https://www.classiczcars.com/forums/topic/31099-is-a-used-280zxt-worth-450/#findComment-277025 Share on other sites More sharing options...
