Email logins are now active ×
Recommended Spares
John7273Z
Front brake rotors (2)
Front brake calipers (2)
Front brake bleeder screws (2)
Front "S" brake lines (1)
Front hub (1)
Front lug bolts (4)
Lug nuts (16)
Front brake pads (2 sets)
Rear brake drums (2)
Rear wheel cylinders (2)
Rear brake lines (1)
Rear brake shoes (1 set)
Master cylinder (1)
Front lower control arm w/ bushing & ball joint (1)
Front wheel bearings inner/outer (2 sets)
Rear lower control arm w/ bushings (1)
Stub axles (1)
Companion flange (1)
Rear wheel bearings (2 sets)
Cotter pins (various)
Complete built up halfshaft (1)
Complete built up driveshaft (1)
Rear lug bolts (4)
Front diff mount (1)
Front diff strap (1)
Trans mount (1)
Engine mount (2)
Transmission (1)
Clutch (1)
Pressure plate (1)
Clutch slave cylinder (1)
Tie rod end (2)
Fuel pump (1)
Fuel filters (2)
Fuel hose (6')
Hose clamps (various)
Head gasket (1)
Valve cover gasket (2)
Fan belts (2)
Radiator hoses (2)
Heater hoses (8')
Oil filter (1)
Oil lines (6')
Oil fittings (various)
Spark plugs (12)
Distributor cap (1)
Pints and condensor (2)
Plug wires (1 set)
Wiper blades (1 set)
Alternator (1)
Regualtor (1)
Wire (various)
Fuses (various)
Fusible link (2)
Battery (1)
Battery cables (2)
Starter and solenoid (1)
Thermostat (1)
Thermostat housing gasket (1)
Carburator rebuild kit (2)
Throttle return springs (2)
Air filters (2)
Exhaust header (1)
Intake/exhaust manifold gasket (2)
Carburator gaskets (4)
Header to exhaust system gasket (4)
Radiator (1)
Radiator cap (1)
Dry Tires (4)
Wet tires (4)
Wheels (4)
And I'm sure I'm missing something. BTW... NOBODY ever has all of these spares at an event.
John Coffey
johnc@betamotorsports.com
