I am a new member so HI everyone. I just recieved a 73 240 Z with terrible wiring, broken,naked, ect. Where can I get a decent wiring harness?
Maybe someone out there has one? hopefully. Thanks and have fun life is to short. Mike
https://www.classiczcars.com/forums/topic/31112-73-z-wiring-harness/
i have a wire harness with gauges in great shape with fuse box asking 250.00 plus shipping. i have sold items on ebay look under carsdatsun for my profile i tryed to send pictures but it is asking me for a security profile
There are 3 harness's in your 73' Which one(s) are you looking for.
Engine harness (from the temp sender to the firewall
Dash Harness (from under the dash
Body harness (from right side dash to left rear corner
If you can find a '72 240 harness the only difference is the '73 has intermittent wipers. Now that is if you change the whole harness. The wiring is the same but '73 used fewer and larger connectors. I rewired my '73 with a complete '72 harness from one end to the other. You need to add a yellow wire from the combo switch to the wiper motor to make the intermittent work. '71 and '72 are the same.
Gary
i also have wiring harness from my 73 240 parts car. in good shape the only thing i noticed was one of the plugs that go into the wiper switches was a little melted. anywho.. let me know if you want to buy.
