Ok, I have been working on my 72 240Z fuel system today. As most of you know I just did a motor swap. With that the fuel line had been left unhooked for a few days. Well I got it all hooked back up today and notice that there are air bubbles along with fuel thats going into the fuel filter. Now its pulling fuel from the tank and keeps the filter full without any fuel leaking back. But it seems that no matter how long I turn the motor over I still get air bubbles from the tank. Is this a normal thing? If not where should I start looking?
No I have not run the motor yet nor have I even tried. I am just taking my time and looking to make sure everything is good before I run it.
Thank you in advance.
https://www.classiczcars.com/forums/topic/31114-air-bubbles-in-fuel-filter/
This is the stock style filter on the inner fender. I can watch the air come up from the main fuel line so it's not a crack in the filter. I did have a crack in the line from the filter to the fuel pump. But that would let the fuel drain back into the tank and empty the filter. I noticed this when I replaced that line and was watching too see if the filter would drain again.
I will take a closer look at the filter case tomorrow. But dont think thats the case.
  Zforce said:
Maybe the pick up tube in the tank has a small hole in it,have you looked at it with a full tank of fuel?
Could be the pick up tube, more likely the hose, or an issue with the aux pump if your car has one.
For air to get in there from suction, something is not sealed properly...
Will
Thank you, I wasnt sure how the tank was set-up inside. I have it at just over a 1/4 tank now. I didnt want a full tank with the odds being so good that I would need to drop it for a cleaning.
