first fuel lines. on the 280z theres three lines the 240 only has 2. so im not sure what to do with the 3rd line. the fuel filter has one in and one out.
so i know that one from tank-pump-filter= main fuel line.
than i guess the second is a return fuel line? which one would that connect to? and what the heck do i do with the 3rd one?
on carb fuel rail setup they're two fuel lines. i guess one is a main fuel line and the other is a return hose?
i numbered the pipes to make explaination easier.
Second. i forgot to take mental note of what went where. i was losing daylight and wanted the weber carbs out fast so i can clean them during the night.
also if any of you are interested in the progress here is a link to my Blog
http://www.cardomain.com/ride/3072832
Edited by overdrivex
actually that is useful but not in this case since the 280z didnt come with carbs originally. and the coolant hoses are associated with the carbs. and the problem with the fuel lines iw more of what to do with the 3rd fuel/return or vacuum line that goes to the tank.
i read into some more and i've decided im probably gonna just have to cap it off. unless some one can chime in on what to do with the 3rd line. the connection are non existent on the carb system. i guess i can just install the carbon filter and plug the 3rd line into that, but it still leaves me with what to connect the carbon filter to. the carbon fileter connects to a bunch of vacum lines on the fuel inj. manifold.
I went to NAPA and they did me good on the 240Z fuel line search....
I was originally inspired to write on the initial quote: "280z theres three lines the 240 only has 2"
My 240Z had three lines: Fuel Supply, Fuel return. and some imaginary fuel vapor recovery anti pollution bull $^!#.... Opps... pardon me...
Jay
Not just a Z - zdisease
On the 280 you have 3 lines.
1 to the carbon canaster
2 to the fuel rail
3 the return line
Pic 2
1 ?EGR?
2 ?
3 PCV Valve
Best I can tell you from the picks and off of the top of my head.
