Posted March 13, 200916 yr comment_277260 can any shop of any kind have these housings threaded for coil over uses? Link to comment https://www.classiczcars.com/forums/topic/31142-strut-housings/ Share on other sites More sharing options...
March 14, 200916 yr comment_277415 I believe the strut housing is normally cut down and a threaded portion supplied with coil-over kits is welded in place. Some more searching should get you some answers. Link to comment https://www.classiczcars.com/forums/topic/31142-strut-housings/#findComment-277415 Share on other sites More sharing options...
March 14, 200916 yr Author comment_277443 yeah, but i figured the sleeves are the same size in circumfrance as the struts, so i would think if i can thread put in it i can dump the sleeves and just use the adjustable perches Link to comment https://www.classiczcars.com/forums/topic/31142-strut-housings/#findComment-277443 Share on other sites More sharing options...
March 14, 200916 yr comment_277447 The sleeves are not the same OD as the strut tubes. 240Z strut tubes are 2.005" OD and 260/280Z strut tubes are 2.15" OD. Typical threaded collars are 2.39" OD.Also, there's not enough wall thickness in the strut tube to accommodate the 70% thread you'll need for a custom spring perch. You can cut off the strut tubes and weld a threaded shock tube in its place, which is what I did when I ran Penskes on my 240Z. Link to comment https://www.classiczcars.com/forums/topic/31142-strut-housings/#findComment-277447 Share on other sites More sharing options...
March 16, 200916 yr Author comment_277644 i was thinking of cutting off the tube from the perch and wedlding in a slimmer tube for the sleeve to slide in, but iono what to do with the bolt that holds the strut in, any ideas on this? Link to comment https://www.classiczcars.com/forums/topic/31142-strut-housings/#findComment-277644 Share on other sites More sharing options...
March 16, 200916 yr comment_277646 i was thinking of cutting off the tube from the perch and wedlding in a slimmer tube for the sleeve to slide in, but iono what to do with the bolt that holds the strut in, any ideas on this?Save your pennies and buy a coil-over kit........ Link to comment https://www.classiczcars.com/forums/topic/31142-strut-housings/#findComment-277646 Share on other sites More sharing options...
March 16, 200916 yr comment_277674 You need to spend a few hours and read this thread:http://forums.hybridz.org/showthread.php?t=138601 Link to comment https://www.classiczcars.com/forums/topic/31142-strut-housings/#findComment-277674 Share on other sites More sharing options...
March 16, 200916 yr Author comment_277731 i do have the coil over kit, it just doesnt slide in the sleeve is a tad bitsmaler then the OD on on the strut tubethx alot john good info =D Link to comment https://www.classiczcars.com/forums/topic/31142-strut-housings/#findComment-277731 Share on other sites More sharing options...
March 16, 200916 yr comment_277732 Are you trying to put sleeves on your 280Z strut tubes? Link to comment https://www.classiczcars.com/forums/topic/31142-strut-housings/#findComment-277732 Share on other sites More sharing options...
March 17, 200916 yr Author comment_277744 actually im trieng to put em on my 240z tubes, but i do have 280 ones aswell Link to comment https://www.classiczcars.com/forums/topic/31142-strut-housings/#findComment-277744 Share on other sites More sharing options...
